My Cylinder #6 Misfire Episode
Two months ago I purchased a 2004 Westminster Edition Discovery, drove it home from Connecticut with no issues. Maybe a week or so later, SES started to show with these codes
I relocated the coil packs, change all fluids, plugs and Kingsborne wires. Reset and drove few hundred miles and SES showed again with these codes.
At this point I decided to replace all the injectors and all code disappeared. Few hundred miles again It started to show misfire at # 6 and every morning at start up Ses will blink and misfire code at #6 cylinder.
Changed wire and plug and was good for few miles and code at #6 will show up again.
I noticed that white smoke appears on start ups in the morning and disappears after warm up. Truck runs fine and has power. Only at start up when the SES blinks. I decided to get an inspection camera yesterday oct 3 to see whats going on in the cylinder. But before that, i ordered Head gasket kit incase my thinking was confirmed. Upon inspection i saw cylinder #6 was clear and not crusted.
I just confirmed that 6 was taking in coolant. Today, i started the process of replacing the head gasket.
At this point, i have not seen the #6 yet and will leave it for tomorrow. I am hoping its just the head gasket that leaked.
Usually that is not the case, I had a similar episode, only with misfires on 6 and 1. Found coolant entering 6 between the block and head... and nothing much wrong with 1. Turns out my mechanic thinks its a crack in the block behind the liner in 6 as the coolant passages from the heads to the block do not go near the inner 4 cylinders, only the ones on the 4 corners. A head gasket leak usually happens on 1, 2, 7, or 8. An internal issue usually happens on 3,5,4, or 6.
Good Luck!
Good Luck!
YIKES! Fingers crossed. Its early morning and a friend of mine called to have me retrieve some security footages in his catering hall and i wont be able to get the problem head out today.
I ordered some bottles of Steel Seal as my last resort if im having some airlock in #6. Ill just try a new product. Hehehe! I was rwading your comments and it could be real that #6 is far from the coolant main passage ways as i imagine but i was also thinking that cylinders must be equally cooled by coolant somehow and there must be a way it gets there. Well, i can only do so much and try whats possible. But anyway, OffroadFrance has another thought about this and something to think about. Lol!
*probably want to bypass your radiator!
