My disco won't start.
Old Jun 6, 2008 | 09:14 AM
fazekas123's Avatar
Default My disco won't start.
My disco won't start, then a couple days later it starts and runs for a week or two then it won't start again. I got mechanic come to my place and messing around with a relay (plug-unplug) it got it to start again. He measured the pump pressrue its at 30. He says should be around 35-37. Is that true? Anyway I bought a new relay but that did not fix the problem. This morning it won't start again after using it for 2 weeks without problem. Any ideas? Its '99 Disco 1st series. By the way its cranking properly and jump cables don't work.
Old Jun 6, 2008 | 09:33 AM
unstable's Avatar
Default RE: My disco won't start.
basic premise of an engine is SPARK + FUEL = COMBUSTION.
If one or the other is not present, the engine will not run.
Have you checked for spark and fuel at the engine?
Old Jun 6, 2008 | 09:42 AM
fazekas123's Avatar
Took it to tune-up 6 months ago. Got new plugs and wires, belts. How can I check for spark?
Old Jun 6, 2008 | 09:45 AM
So lets start with year, and mileage.
Do you get a check engine light, if so what fault codes?
Check and see if your crank sensor is oil soaked.
Old Jun 6, 2008 | 10:19 AM
fazekas123's Avatar
1999 Discovery 1, V8. 4.0L , 80,000 miles. No engine lights. Need to find location of crank sensor. I am a newbee as far as fixing cars, but I am motivated and fast learner. I have the service manual and I will try to find it.
Old Jun 6, 2008 | 10:27 AM
NiteTrain's Avatar
ORIGINAL: unstable
+air +compression
Old Jun 6, 2008 | 12:00 PM
unstable's Avatar
touche' nitetrain. but to restrict air or to have no compression without realizing you have bigger problems would be difficult to accomplish...I'd expect.
Old Jun 6, 2008 | 12:05 PM
fazekas123's Avatar
Can't find crank sensor in the manual, is there is another name it goes by? I also remember couple of week ago after filled up at the gas station I started the car and when I was waiting on ramp to get out the idle droped down for about 5 seconds then it when up again.
Old Jun 6, 2008 | 12:47 PM
NiteTrain's Avatar
fazekas, might be under crank angle sensor.
unstable, If you have no compression it's likely that your rings have collapsed or you have a stuck vavle...those are pretty big problems. However, I do agree that you should always check fuel and spark before moving on to compression when you have engine problems.
Old Jun 6, 2008 | 12:55 PM
NiteTrain's Avatar
fazekas, this webpage shows the guy removing his from the drivers side rear of the block. He says it's a 4.0L but he's working on a D1 so im not sure. Did they put some 4.0L in D1's I thought they all had 3.9L?
http://home.twcny.rr.com/eeibooks/rover/engine.htm
