My first Rover, and first post!
CollieRover (01-19-2020)
Well, as good luck has it, I may have stumbled upon a fairly well maintained Rover.
All fluids are full, to include both diffs, transfer, and so on. I have not done the auto trans yet, but tomorrow it is going down.
Also, the front drive shaft is a brand new replacement with zerks, and the rag joint is new on the rear driveshaft/diff.
So far, so good. I posted pics, but they are not showing as a mod apparently has to approve them?
Jeff
Jeff
Received 1,189 Likes
on
You have to check the trans fluid while it's running, in neutral, level ground, parking brake applied. Pull front plug and trans fluid should come out in a small 1/8 diameter stream. If fluid comes out, it's full, if not...add some. If you remove plug while not running...fluid will pour out and you'll lose a couple quarts worth.
Do quick search here for filter/fluid change, but you attempt procedure.
Nice looking rover, good luck with your build.
Brian.
Brian.
Well, after a week of ownership, the honeymoon is still not over. (For the "glass is half empty" types, I know, it has just begun), but I have been lurking and reading, reading, reading here for a LONG time, or I would not have bought a D2. I am an experienced off road driver, I just have been too "chicken" to tackle the Discovery's poor reliability reputation.
Hogwash.....Man, what a truck.
It is replacing a very, very tired Toyota FJ60 (318,000+ miles), and already the Disco runs circles around that truck offroad with stock condition throughout. I even got it stuck already, but deep sand in a wash bed and poor line on my part are to blame, not the truck, got the back passenger wheel hooked on a big buried rock. Got it out with a little push by my passenger. Traction control and ABS just flails the Toyota. Never mind the center diff lock.
Wow. I can barely contain my enthusiasm. To be honest, I bought the FJ60 in 2009 because I was too intimidated by Rover maintenance so I compromised.
Big mistake, I am sold. I can handle the maintenance, it is worth the rewards of this great truck. I should not have waited.
Jeff
Jeff
Jeff
Jeff
Thanks, guys.
I love the FJ60 also, but it is no Land Rover, it is certainly bare bones! And I will heed the cooling system advice, I watch the temp gauge more than the speedo so far.
Maroon was never my favorite, but it is also growing on me...I bought it for the drive train, so the color is just an afterthought.
Jeff
Jeff
