My New 04' Disco II SE
Old Jul 17, 2010 | 04:23 PM
FightOnUSC79's Avatar
Talking My New 04' Disco II SE
First time LR owner and so far am blown away with this vehicle and it has only been me for 4 hours! Took few months of searching and some wheeling and dealing, but here it is.
As a first time LR owner and tips and tricks will be greatly appreciated.
Attached Thumbnails My New 04' Disco II SE-dscf2027.jpg   My New 04' Disco II SE-dscf2028.jpg   My New 04' Disco II SE-dscf2029.jpg   My New 04' Disco II SE-dscf2030.jpg   My New 04' Disco II SE-dscf2031.jpg
Old Jul 17, 2010 | 05:41 PM
vandev's Avatar
Default Congradulations..
Congradulations and welcome to the short bus crew....
1st; try not to mention the word blown, as they have a tendency to do that..
2nd; develop and thick skin and a real big sense of humor...
3rd; this will require excessive alcohol to help with fixing things on your truck
4th; read threw the 60k service and do it....if no mechanical experience, go find a indy LR mechanic and become his best friend. Bringing 12 packs by on friday afternoons will get you points... If not, your in for some real pain...mentaly....
5th; if you do have a question or problem, post it here after you read threw the posts, rave which you can download here, and post symtoms.... and then just beg....
6th; when you exhaust all 5 steps , go to step 3...that will usally solve it...
Welcome to ....well.....you'll figure it out and it's not disneyland...
Old Jul 17, 2010 | 10:27 PM
'BamaBoy's Avatar
Keep up on the maintinence, ALWAYS premium gas, and definately the 60k service and she will treat you well
Old Jul 17, 2010 | 10:52 PM
Default My New 04' Disco II SE (Repairs done since April 10')
The Truck just turned 100K on the odometer, I have the receipts from the work done about 2 months ago where the following was replaced:
Oxygen sensor Front:
Oxygen Sensor Rear:
Replaced Radiator:
Coolant Hose Rad Upper:
Coolant XLC Orange:
Replace Coil Assy W/bracket OEM:
Replace Ignition Cable Set wit A.I.R Pump
Ignition Coil (1 Bank)
Oil and Filter Change (4/10/2010)
Replace A/M Intermed Muffler OEM
Replace LC Converter California OEM
This is all work that the vehicle had completed in April of this year, on top of these fixes what else should i be looking for? I know the Drive shafts need to be Rebuilt or replaced, is there a particular brand i should go with and what should i look for to see if it has already been done.
Thanks Again
Old Jul 18, 2010 | 03:54 AM
03discoman's Avatar
rebuild the drive shafts and install an oil pressure gauge ASAP
Old Jul 18, 2010 | 07:22 AM
vandev's Avatar
Default good advice
good advice....
Old Jul 18, 2010 | 09:36 AM
Glad you finally got what you were looking for.
Old Jul 18, 2010 | 10:34 AM
ljdiscovery's Avatar
the discovery will give you something fun to do during the upcoming football season when USC is on probation............ Phil
Old Jul 18, 2010 | 11:25 AM
Default Thank you
Thanks for all the tips, I am now going to spend my day researching the drive shafts and a place to have it done around here.
I don't have a house yet so i am at a loss for doing it myself, which i believe i could handle, but doing it in the parking garage of my building might not be kosher with the management.
Phil: I can see we will get along smashingly!
Old Jul 18, 2010 | 08:53 PM
It was a grind and it only became easier once I found this forum and all the help it had provided.
Thanks again
kayak74
Jan 23, 2013 07:13 AM
wisconsinoverlander
Oct 1, 2012 09:34 AM
