My Rover is Dead
My Rover is Dead
Hi all,
New to the group but have a problem that has got me stumped.
I have a 2000 disco II with 150,000
Started it one morning and it started to stumble, put it in reverse and it died.
would not re fire and hasn't since.
I jumped the gun because it acted like it ran out of gas and put a new fuel pump in it.
still wont start.
I start to diagnose.
Pump is not running, not even a prime.
no power getting to the pump
check all fuses all good.
Rotate Fuel pump relay, no change.
press inertia switch, no change.
jumped wire on inertia switch, set off alarm and now the two green lights on the dash flash when I crank it.
Removed fuel pump relay and jumped it, pump runs when jumped.
even with that it still wont start not even a pop.
pulled wire and put extra spark plug against manifold and have spark.
buy the way I put new coil packs, wires and plugs in it last year.
pulled boot off intake and sprayed starter fluid in it, still wont start.
because it wont start with starter fluid I decided a CPS was next on the list. Still wont start.
Checked ground wire to fire wall, looks good
Checked alarm, armed it disarmed it, I think it is working fine.
I'm stumped have no more ideas, anyone out there that has heard of this and can help would be my hero.
thanks
Darin
still wont start.
thanks
Darin
Yes 6 I think mostly my doing but the anti theft one has me thinking
1. P1668 indicates the PCM detected the anti-theft alarm signal was greater than the maximum allowable limit.
2. P0444 indicates that the Evaporative Emission System Purge Control Valve electrical circuit was open for a predetermined period of time. I in unplugged it
3. P0560 indicates a fault in the System Voltage for a predetermined period of time.
P1536: Air conditioning compressor power stage faultDrive cycle A:Signal missing
Code P0650 indicates a fault in the Malfunction Indicator Light Control electrical circuit for a predetermined period of time.P1230: Fuel Pump Relay Open
Those codes are probably from turning it over and the battery got low or is low. Make sure the battery is fully charged, and all terminals are clean and not damaged.
I’d borrow a good scanner that can monitor modules like the engine management Icarsoft LR2 comes to mind. Then you can fully verify CPS operation.
You have spark, but no start. You have fuel pressure, but no start. You changed CKP sensor, but no start. It is pretty low probability, but you might have a bad ECU.
Try this, buy a replacement ECU/BCU/Inst Cluster set off ebay, see if your trucks starts. If it does, sell your BCU and Inst cluster on ebay. If it does not, you can always resell the parts on ebay.
Or, squirt a little gas through the throttle body, see if it hits. If you have spark and compression it will fire/hit, even if it only runs a couple seconds.
Had the vehicle been sitting for an extended amount of time? Or did you buy fuel recently (right before this issue started) at an off the wall gas station? I'm surprised it wouldn't start temporaily on starting fluid, if you have spark. Of course the plugs could be all fouled from bad fuel, too.
I guess you need to verify fuel pressure (just because pump is running doesn't necessarily mean it's creating enough pressure), check to make sure fuel injectors are firing, check for spark at all cylinders, check compression and timing. As mentioned, a scan tool would really help you out in this situation, helps eliminate some guess work. And the ECU occasionally going bad has happened from what I've read on this site.
Make sure you have a fully charged battery, with clean-tight connections, while trying to start also.
Brian.
Brian.
