My Snaped Stud Hell
My Snaped Stud Hell
Hello All am after some help and advice
So i had an exhaust stud snap when trying to refit the manifold and then the drill bit snapped off leaving me with this mess a 10+mm hole where the stud should go. now i don't have a tig welder so cant weld it up. is there anything i can do or is it scrap
thanks
thanks
I'd try a "timecert" that inserts into a predrilled hole. I've used them several times on aluminum engines. No need to pull head, just buy appropriate kit, drill hole and insert timecert as directed. Even if you had to bump up to the next size stud, just file the hole in the manifold to allow for larger stud.
Brian.
Brian.
Time Serts are a "solid" sleeve and heli coil, well it's a coil/spring. Google it again and you will see the difference.
For this repair it's a Time Sert all the way.
Banzai Jimmy (09-03-2019)
ahab (09-04-2019)
