My Turn! Overheated today!
Old Sep 25, 2017 | 05:22 PM
LR03NJ's Avatar
Default My Turn! Overheated today!
Wife called she overheated. Reached 240 and she said she turned engine off . She called AAA and home now. I checked where the leak was a moment ago and it was I THINK BETWEEN THE PULLEY AND THE COOLANT PUMP. Any special part that I need to order or replace? Definitely I'll replace the pump, but is it easy to replace? 2 hours? 3 hours or entire day. Is it as easy a a drive shaft? Thanks
Old Sep 25, 2017 | 05:29 PM
Best4x4's Avatar
It could just be the small rubber hose between the pump & the plastic y pipe. I’ve seen a few LR’s have issues in that spot due to weak, cheap, or rusty clamps.
Old Sep 25, 2017 | 05:33 PM
LR03NJ's Avatar
I'll check again. Just letting it cool down a bit. I'll let you know thanks
Old Sep 25, 2017 | 05:37 PM
The hardest part of doing the pump is getting the damn fan off
Old Sep 25, 2017 | 06:07 PM
mollusc's Avatar
Gerry, I have fan tools you can borrow if it comes to that.
Old Sep 25, 2017 | 06:42 PM
LR03NJ's Avatar
I got an app for that! Actually, I just replaced the lower larger than an inch short hose less than 2 weeks ago when it burst. I just want to know if I need to replace the entire pump or just the gasket. Well, I guess the entire assembly instead.
Old Sep 25, 2017 | 06:48 PM
LR03NJ's Avatar
Thank you so much Bro, I think I'll be able to find mine somewhere when I did the HG. I'll see you one day, when we get blizzard here. LOL!
Old Sep 25, 2017 | 07:05 PM
Jeff Blake's Avatar
Sounds like you have the fan tool squared away, but if anyone else is interested, I picked up the official fan pulley holder tool for about $90 bucks. Well worth it in my opinion for easy repairs
https://www.lrdirect.com/LRT-12-093-...Coupling-Tool/
and optional https://www.lrdirect.com/LRT-12-094-...upling-Wrench/ (or use 36mm fan wrench)
Old Sep 25, 2017 | 08:01 PM
mln01's Avatar
Or you can make one that does the job just as well with an 18 inch piece of 1 inch steel bar from your local big box home-improvement store a little time with an electric drill.
Old Sep 25, 2017 | 08:03 PM
mln01's Avatar
I helped a guy in my neighborhood change his DII water pump a few years ago. Seems to me it took a couple hours and we were not in any hurry.
Cleaning the mating surface of the front cover was probably the most challenging part. You never know how that's going to go. One good thing is that with the fan and the pump out of the way there is a reasonably good amount of room to work on the mating surface.
The unbolting and bolting is not big deal if you follow the RAVE instructions.
