My Wife Bought Herself a Disco - What do I do first?
Old Nov 19, 2013 | 10:54 AM
SuperSport's Avatar
If your truck is an SE or higher, and leather seats, then you do have heating elements, likely.
Old Nov 19, 2013 | 11:04 AM
dr. mordo's Avatar
Originally Posted by LolisDisco
I have a very good independent parts shop that can install the u joints if I buy them there. Is it ok to do that or do I need to go to a drive shaft shop?
Thanks
Eric
I agree with Dusty1, should be fine. But be absolutely certain they replace the centering ball as well. The centering ball is what fails on these things and destroys the u-joints. I've read stories about shops doing the joints but not the ball. I'd be absolutely certain they understand you want the centering ball replaced, then I'd ask about it afterward to be sure they did it.
Honestly, you might be better going to a driveshaft shop, just because I'd trust them a bit more to do it right. These shafts are kind of a pain to rebuild.
Old Nov 19, 2013 | 11:16 AM
drowssap's Avatar
"be absolutely certain they understand you want the centering ball replaced"
Old Nov 19, 2013 | 11:20 AM
poncePR's Avatar
If you are good with tools and have patience you can rebuild the driveshaft yourself for under $100 dollars,just mark its orientation and put everything back by your marks.No balancing needed.That beeing said I would not do it again.I would rather pay premium than to go thru that again.
Old Nov 19, 2013 | 11:55 AM
dr. mordo's Avatar
Honestly, I wouldn't want to do it again either and I've rebuilt several driveshafts in the past.
These are a pretty big PITA.
Old Nov 19, 2013 | 08:02 PM
LolisDisco's Avatar
I read on another thread about a guy on ebay that sells good to go driveshafts for $250. Who is the vendor and is he still a reliable source?
Thanks
Eric
Old Nov 19, 2013 | 10:11 PM
dusty1's Avatar
Yeah, I think those are from atlantic British. If so...reputable, indeed. been around a bit.
Old Nov 19, 2013 | 11:21 PM
LolisDisco's Avatar
The one I found is from lrparts and sells for $250.
eBay item number 290989790595
I have to check some other local sources but one was $350 to modify mine.
Thanks
Eric
Old Nov 20, 2013 | 12:27 AM
SuperSport's Avatar
Thanks
Eric
Here is his website: Lucky8 Llc. - Take the road less traveled...
Old Nov 20, 2013 | 06:41 PM
xxdoylexx's Avatar
so i just went through the whole drive shaft replacement. last thursday i noticed a squeal coming from the shaft. I checked in on friday pulled in on sunday, thought about rebuilding it, even pulled it all apart. then i decided, that I wanted it done right and I didnt have the proper tools to insure i could do it right.
so British parts of Utah has one for 350.00 that they have custom built.
Oriellys sells on for 395.00
lucky8 sells one 250 on ebay delivered or 235 on their website delivered
i went with a drive shaft shop that is local who did it for $300.
i would of bought the lucky8 one but the local drive shaft shop didnt it in hour and i would of had to wait a couple of days for a internet store to deliver it.
