Name/Identify these 2 parts - PHOTOS inside
Old Apr 19, 2013 | 11:32 AM
jthomas's Avatar
Default Name/Identify these 2 parts - PHOTOS inside
Rebuilt engine is back in. Have these 2 parts left over from a box of parts that were removed at the dealer the previous owner took the truck to for overheating issues.
One looks like a heat shield of some sort, the other looks like a bracket for the wiring harness.
Thanks
Old Apr 19, 2013 | 12:08 PM
roverguy7's Avatar
You have the heat shield for the engine mount. The other is the mounting bracket for the purge valve and SAI solenoid on the driver's side of the upper plenum.
Old Apr 19, 2013 | 12:09 PM
upnover's Avatar
The bracket goes on the Driver side of the Intake. It connects the Purge valve, Just a little right and down of the red arrow. The heat shield goes by the brake master cylinder.
Old Apr 19, 2013 | 12:50 PM
jthomas's Avatar
Awesome. Thanks so much.
Old Apr 19, 2013 | 01:09 PM
jthomas's Avatar
Got the bracket installed, but can't get the heat shield on. Is it for the driver's or passenger side? Does it install from the top or bottom?
I couldn't figure out how it would go onto the brake master cylinder - I already saw one squarish heat shield near there.
And which harness connector goes into the round black plastic valve and which goes into the other squarish plastic valve? I have 1 black and 1 grey harness plug that can go into either one.
Thanks
Old Apr 20, 2013 | 03:12 AM
jfall's Avatar
heat shield is driver's side USA.
It is way down there. I think you need to take one of the bolts off via the wheel wheel.
Been a year since I did that.
The heat shield is removed to do head gaskets usually.
Old Apr 20, 2013 | 09:14 AM
jthomas's Avatar
Thanks for confirming the side. I'll have to give it another shot today.
Old Apr 20, 2013 | 09:45 AM
SuperSport's Avatar
It looks to me like that heat shield is going to be a chore to put back.
Attached Thumbnails Name/Identify these 2 parts - PHOTOS inside-heat-shield.jpg
MonteroMan
Off Topic
17
Jul 6, 2014 08:29 PM
Childeric
Mar 21, 2014 01:41 AM
gribur
Mar 14, 2014 04:00 PM
fem
Mar 4, 2012 10:46 AM
rarick123
May 31, 2007 08:57 PM
