Nanocom?
Old Jan 7, 2026 | 06:27 PM
H20nSnow's Avatar
I've used it to successfully troubleshoot an SRS failure (and keys and ABS)...as well as all manner of normal stuff that the alternative scanners could help you with.
Old Jan 7, 2026 | 11:53 PM
Dervish's Avatar
Originally Posted by SouthByWest
Much appreciated. I’m curious as to specifically what other things you use it for, besides the ABS bleed and programming keys.
Reading and writing maps/remaps.
Old Jan 8, 2026 | 08:11 AM
pburgh's Avatar
I bought a project 2002 D2 the other week that needed new fobs. This $125 Launch scanner programmed 2 new fobs without issue and seems to be capable of many other things like ABS pump cycling, etc. although I haven't tried it yet. Mainly purchased it knowing it could program new keys. That being said, it's a bit fiddly and required programming each key twice before it prompted syncing with the BCM, there are several YouTube videos on the process.
Amazon Amazon
Got these fobs and had a local locksmith copy the original key:
Amazon Amazon
Old Jan 13, 2026 | 08:21 PM
roverboy40's Avatar
I’ve used my Nanocom to set adaptive values on both my Disco 2 and NAS Defender. It’s a great tool and worth the investment.
Old Jan 28, 2026 | 01:09 PM
Diesel Gypsy's Avatar
I was just looking at the Nanocom website and they list a whole bunch of models.
Would I need the Motronic V8 version or the Lite version? Is my 2000 V8 considered "Motronic"?
What advantage is the Motronic version considering it is twice as much money?
Old Jan 28, 2026 | 01:56 PM
pagoda's Avatar
I have a 2002 V8 (Bosch) and having spoken to BBS, the item they said I required was the Nanocom Evolution for Motronic V8. Arrived in good order; very happy with it having used it pretty extensively if not for anything more complicated that faults, live values and bleeding the ABS. It's expensive, but it's way better than any of the generic FCRs I've had. (Now if only the GAP IID tool worked on the D2 - that thing is next level).
Old Jan 28, 2026 | 02:55 PM
What is a GAP IID ?
Old Jan 28, 2026 | 08:04 PM
Harvlr's Avatar
Yes Motronic, which means it's a Bosch ECU. That's the correct Nanocom Unlock program for all Discovery 2's (mid 1999 to 2004).
Old Jan 28, 2026 | 08:29 PM
pagoda's Avatar
Originally Posted by Diesel Gypsy
What is a GAP IID ?
The GAP IID tool is a Bluetooth OBD2 tool that works with an advanced app on a phone/tablet and which works only with LR with OBD2 compatibility. For me that’s my LR3 LR4, etc. Those vehicles have a ton of sensors, inputs and things to go inexplicably wrong for no reason whatsoever. It doesn’t work with the D2, sadly, but I’d have a newer LR it’s an absolute must.
Old Jan 28, 2026 | 11:42 PM
Harvlr's Avatar
Pagoda, what you're saying about the Gap Tool being incompatible with the D2 is probably correct (I have no experience with the Gap Tool), but Disco 2's are OBD2 compatible.
I've never heard of anyone regretting buying a Nanocom.
