In need of a cheaper T-case
Well. Mine is bleeding oil like no other and the it looks like the front output shaft is almost kaput. There is a decent amount of play in there now and I think it's ruining my front driveshaft.
I'd like to get another on the bench so I can swap out what seals I can, clean is and just swap them out over the weekend.
It needs to have CDL
I'm currently in southern California if anyone has anything
I guess I need to know if I'm wasting my time trying to replace the one front output bearing and the seals by removing my t-case.
If anyone has done this job I would appreciate some input
Haven't done the job, and my lunch break is over so I'll make it quick:
Sounds like it is doable, even in place (but a PITA). Much easier, allegedly, if you can drop it in place on a hydraulic platform/jack.
Honestly, I wouldn't worry about getting another new T-case just yet. I'd drop the one you have, fix the seal, and call it a day.
T-case is an LT-230. I did a quick search for you and brought this up. Most are defender owners (I guess we disco owners don't use ours off-road enough to make them fail! Or maybe our Cardon shaft keeps stresses down so it doesn't usually fail):
front output shaft bearing LT230 - Defender Forum - LR4x4 - The Land Rover Forum
They claim it's not that difficult, with the proper tools of course.
Good luck!
Good luck!
