Well... LRDirect is pretty cheap including the international shipping
https://www.lrdirect.com/ SSW500030 rear is $26.65 each SSW500020 front is $26.75 each $20 bucks shipping to WA |
Hey guys, found some closure.
Cheap sensors were contacting the reluctor rings. Spaced them out but foxwell tool was showing 0mph on all three of them. So spaced them out with o rings pinched under the body of the sensors. Got speed readings but it immediately threw codes for all 3 sensors. Tried one more time with some super thin plastic washers, worked like a charm. cleared the codes and the lights stayed off. So lesson learned, cheap sensors need to be massaged a little to work correctly. Thanks for the Input yal! |
King any pictures? Got 3 amigos now. LOL!
I used a relatively cheap sensor ($30), I'm getting cut wire code, not low output or whatever it would say if the signal was crap. Does that mean the sensor is bad and I should get another one instead of adjusting washers o rings etc?
Originally Posted by LR03NJ
(Post 629464)
Originally Posted by huggi
(Post 629478)
An ABS or LR Specific code reader will help a lot. I've used Ebay 45.00 for the entire set of ABS sensors without any issues. I normally always replace either per axle or all 4 when messing with ABS sensors. I compared the last set of generic ABS sensors to the OEM units and I didn't see any difference.
I used to think the ABS 3 Amigo's was a big deal until I got myself a decent scantool, and I read up on the Option B Mod which is the main weak link in the system. I'd say do the Option B Mod with a new set of shuttle valves (60.00 tops), after buying a D2, and maybe even the sensors themselves and then have a good long while until they pop up again. |
Originally Posted by Best4x4
(Post 629528)
