Need the collective wisdom of the forum elders.
Old Feb 2, 2019 | 09:19 AM
Ben Matheson's Avatar
Default Need the collective wisdom of the forum elders.
I'm down to the last item on the to-do lists on my truck and it's a VIBRATION issue. Ive read through all the other vibration related threads and gone through a decent amount of diagnosis but haven't found the cause yet.
Vibration is at 75-85 mph
Vibration is present if I run it up to 85 and drop into neutral
Vibration is a little stronger on decel and I can mitigation it slightly with a smidge of positive throttle
Vibration is heard as much as felt.. it's a harmonic that hums like I have 2 wheels on the rumble strip of the edge of the highway
Front shaft was replaced with new.. no change
Had a shop reseal the tcase and no mention of output shaft slop.
Same shop checked all 4 wheels for play indicating hub or bearing issues
Tires recently replaced and balanced twice
Rotoflex checked and while not new appeared to be crack free
Alignment done with new tires
Not sure what to check next. I know the problem can be solved and is probably something simple but I need some ideas
Old Feb 2, 2019 | 09:31 AM
Saturnine's Avatar
Warped brake rotor? Tcase fluid low?
Its gotta be post transmission
Vibration doesn't appear to be in the front end as there is no wobble or vibration in the steering wheel.
Old Feb 2, 2019 | 09:44 AM
Recently replaced complete brake system with new rotors
Tcase resealed last week and fluid filled
Old Feb 2, 2019 | 09:45 AM
Has anyone ever had a parking brake drum cause anything like this?
Old Feb 2, 2019 | 09:57 AM
Friday Night Disco's Avatar
You can slightly engage the parking brake and see if the vibration and noise increases.
i was thinking it could be an exterior part that is catching air. My cb antenna causes a sound between 50 mph and 70 mph
Old Feb 2, 2019 | 09:58 AM
Nosugar0carbs's Avatar
What wheel combo? Hubs?
Old Feb 2, 2019 | 10:05 AM
The Deputy's Avatar
That's a pretty high speed vibration, for sure. Seems weird that it comes on at only 75 mph, or above. My first thoughts would be tires at those speeds, but you've address those. So, I'd check the front u-joint on the rear shaft (it doesn't have to have sloppiness necessarily, it can be dry inside and binding) and look for signs of the balance weight being gone off the shaft (usually looks like two/three dimples where it was once spot welded on).
It seems like it is hitting it's "sweet-spot" for creating the vibration at a certain speed. Usually, again, usually...transfer cases, rear ends, wheel hubs and such come on slowly and gain vibration with speed...not all at once.
Driveshaft balance or binding can be more like you are describing, all at once.
​​​​​​​ Brian.
Old Feb 2, 2019 | 10:18 AM
Yeah something is hitting a resonance. I'm thinking of having the rear tires pulled off the rims and checking for a bent rim. Maybe a lateral bend wouldn't be noticed until it hit the perfect speed?
I equate the effect as similar to a cell phone sitting on a table with the ringer off and just the vibrate function on. You can feel it and hear it
Old Feb 2, 2019 | 10:25 AM
Stock hurricane wheels no spacers
