Need custom plug for SAI removal
Received 1,189 Likes
on
Sixpack577 (04-15-2020)
@RoverPA Yup it will. It is a bit of pain to work around but you can remove the studs on that hold the SAI to the upper intake and replace with bolts that helps a bunch. I have been trying to figure a way to relocate the aluminum tubes at the back of the engine compartment, no good plan so far.
RoverPA (07-16-2020)
on
Yeah, if you don't want to ruin the tubes, to remove large nut, then welding is a good option. Only thing that becomes regrettable, is you lose the allen head fitting in the center...makes spinning them out easier than using a 18mm wrench on that square section. Was fortunate, had a coulpe old sets of SAI tubes that were cracked...so cutting them to remove large nuts was an option. But, if you don't have an extra set...welding works.
It's a special thread for the heads. I think it's 5/8 fine thread. The tool to thread a plug isn't worth the cost.
I welded the end of my SAI plugs. Here's a video of me welding the ends. I'm no pro welder but it didn't leak exhaust.
https://youtu.be/lR-aT7U91D4
im looking to buy a cap to just thread on do you know the thread pattern on them?
conrad1468 (01-04-2024)
