Need custom plug for SAI removal
Old Apr 15, 2020 | 01:15 PM
The Deputy's Avatar
Yeah, cut the tubes, remove the large nut, put a nickel inside the nut and reinstall it on head fitting. Yeah, it will be another twenty cents wasted on the thing...but in the grand scheme of things...it will probably be the cheapest fix ever.
Old Apr 15, 2020 | 02:01 PM
TimInNova's Avatar
... it will be another twenty cents wasted on the thing...but in the grand scheme of things...it will probably be the cheapest fix ever.
Amen to that. This things sucks up my money like a biscuit in gravy
Old Jul 15, 2020 | 11:45 AM
badkarma's Avatar
6th Gear
Default SAI removal
So I'm doing a head gasket job on my 03 disco 2 that has these freaking things. They are in the way of my headbolts. How do I remove them is it a hex head if so what size. Thank you for any wisdom you guys can give
Old Jul 15, 2020 | 06:49 PM
Extinct's Avatar
Remove the spark plug wires, put an open end wrench on the SAI plug, then you can unscrew the SAI tube nut with a big wrench, I think 1"
Old Jul 15, 2020 | 06:55 PM
RoverPA's Avatar
Member
Newbie here, got an '04 Disco 2 for $300 and starting to rebuild. Will removing the SAI throw a code?
Old Jul 15, 2020 | 07:37 PM
Richard Gallant's Avatar
@RoverPA Yup it will. It is a bit of pain to work around but you can remove the studs on that hold the SAI to the upper intake and replace with bolts that helps a bunch. I have been trying to figure a way to relocate the aluminum tubes at the back of the engine compartment, no good plan so far.
Old Jul 16, 2020 | 02:03 PM
keninnc's Avatar
A friend of mine took the SAI ports off his P38 with the 4.6 engine.
He says they are M16 - 1.25 threads
Old Jul 17, 2020 | 02:16 AM
The Deputy's Avatar
Originally Posted by TimInNova
I just bought a set (4) of SAI head bolts on eBay and plan to weld them shut and install them. This way I can remove and preserve the entire SAI system from the engine. I like to keep the original parts I remove in case one day I ever want to return it to stock.
Yeah, if you don't want to ruin the tubes, to remove large nut, then welding is a good option. Only thing that becomes regrettable, is you lose the allen head fitting in the center...makes spinning them out easier than using a 18mm wrench on that square section. Was fortunate, had a coulpe old sets of SAI tubes that were cracked...so cutting them to remove large nuts was an option. But, if you don't have an extra set...welding works.
Old Jan 3, 2024 | 04:22 AM
Mo 3's Avatar
Originally Posted by conrad1468
It's a special thread for the heads. I think it's 5/8 fine thread. The tool to thread a plug isn't worth the cost.
I welded the end of my SAI plugs. Here's a video of me welding the ends. I'm no pro welder but it didn't leak exhaust.
https://youtu.be/lR-aT7U91D4
im looking to buy a cap to just thread on do you know the thread pattern on them?
Old Jan 3, 2024 | 06:45 AM
TimInNova's Avatar
Several years ago I purchased the custom made "SAI delete plugs" from user "greisinb" He is the guy who makes the SAI delete plugs. DM him if you need a set. The price is very reasonable.
