Need factory wheel/stud/hub info
Old Feb 11, 2017 | 12:15 PM
KingKoopa's Avatar
Default Need factory wheel/stud/hub info
I'm hunting for 16x7 aluminum wheels and am exploring options regarding hub rings and even lug converters, the catch is I'm getting conflicted info about the factory wheel specs.
so can someone please set me strait. I need to know the offset for the factory hurricane wheels. I need to know the hub diameter. And I need to know the diameter and thread pitch of the factory lugs. Length on the lugs would be great as well. Thanks in advance
Old Feb 11, 2017 | 12:57 PM
OverRover's Avatar
Offset: 57MM
Bolt Pattern: 5X120
Center Bore (Hub Diameter): 70MM
Lug Nut Threads: M14 X 1.5
Lug Nut Overall Length: 46.5MM
That's all I got..... Good Luck!
Old Feb 12, 2017 | 02:00 AM
Jeff Blake's Avatar
Good luck finding aftermarket wheels, and please post your results. I spend many days searching for something decent. Came up empty. I eventually settled on the Style 2 16x7 factory wheels, though I am still waiting on the backorder. 6 weeks and counting.
Old Feb 12, 2017 | 09:10 AM
Luckyjayb's Avatar
the only options I have seen are the bbs 2 piece from rimmer bros and the terrifirma beadlocks. Other than that just factory unless you use adapters which I don't reccomend at all!!
Old Feb 12, 2017 | 10:29 AM
KingKoopa's Avatar
I've had good luck with adapters in the past and will use them if the overall backspacing is correct and the cost is in line with my budget. Currently there is someone locally selling a set of sparco 's tha I think would look phenomenal
Old Feb 12, 2017 | 10:30 AM
KingKoopa's Avatar
chicane
Mar 22, 2014 11:48 AM
Eaglerover22
Jul 5, 2012 09:01 AM
croller63
Jan 7, 2012 08:55 PM
nynole
Jan 27, 2009 10:08 PM
Tvdmtac
Sep 15, 2007 08:51 AM
