Need Help Again - Where is the best place to get a used engine?
Old Apr 17, 2012 | 08:36 PM
rbaker's Avatar
3rd Gear
Default Need Help Again - Where is the best place to get a used engine?
I am in need of a used 2002 Disco engine.
  • Please let me know any recommendations as to where to get a decent motor?
  • Also, what do you think is a fair price for one with 80K or so on it?
Thanks,
Robert
Old Apr 17, 2012 | 08:46 PM
Discovery SE7's Avatar
Really depends on a few factors. From a car that is scrapped is hit or miss. You could get one with rear end damage, but not know that the owner was already having engine problems before they got rear-ended. Safest thing is to buy a used engine and then send it to a machine shop to be checked, cleaned and fixed (bored, or whatever needs to be done to it).
You can check E-bay (don't think I've ever seen an entire engine), junk yards, auctions (sometimes they sell wrecked cars for the parts).
If you do have one shipped, be mindful that you will have to likely unload it with a fork lift, and most curriers will not deliver to a residential address (probably the most restrictive factor).
Old Apr 17, 2012 | 08:51 PM
Rearden Steel's Avatar
Where are you located?
What is wrong with yours?
Old Apr 18, 2012 | 01:20 AM
discoboy's Avatar
I had my motor replaced with a used unit from Specialized Parts Planet/LKQ out of Rancho Cordova, CA. My motor in my 03 was ticking for a while, spent a lot of time, new parts to try to fix it, did not work. Drove vehicle for 20k miles like that. Then it overheated one morning, tried T-stat, was ok for 20 miles then over heated again, finally after trying to get the vehicle back to my house I noticed the motor started knocking. Finally I figured I am done with this motor. The intake was full of water..I got a used motor with 80k miles from a 2004 D2 for $3300 from them. I knew it was a gamble, but $5k+ for a short block was too much for me to consider. So far 4,000 miles later, so far so good, not even a drop of oil is leaking and of course no ticking. I hope my decision will hold up for the next few years.
Old Apr 18, 2012 | 06:21 PM
rbaker's Avatar
3rd Gear
I am located outside of Madison Wi. The local shop ruined my engine and after months of battling with them, I am ready to move on.
Old Apr 19, 2012 | 06:20 AM
I hope you are able to make them pay, if they screwed up.
Call Paul Grant or P.T. Schram, both their number are in my signature section, they should be able to help you.
By the way, what is wrong with your engine?
Old Apr 19, 2012 | 07:04 AM
JavaRacer's Avatar
Which shop ruined your engine??
Call Clint Paul, the local independent Rover Specialist in Madison. He has done plenty of work on my Disco and is very reasonable and knowledgeable...
Clint Paul
608-274-2313
Mad City Rovers
Home
tnixon44
Apr 29, 2014 01:23 PM
gribur
Apr 10, 2014 08:29 PM
bballjames
Jul 5, 2012 03:12 PM
Sunny side auto
Apr 1, 2011 08:17 AM
Fing Fang Foom
May 5, 2010 09:14 PM
