Need help installing Glove Compartment
Old Oct 13, 2012 | 06:19 PM
aguison's Avatar
Default Need help installing Glove Compartment
Hi guys
I have a question regarding putting back the glove compartment on a 2003 Discovery
I removed the glove compartment to service the A/C blower motor. Wasn't paying attention - removed the 4 bolts at the bottom and the glove compartment came out.
While putting everything back I noticed the glove compartment has rollers on the sides that are spring-loaded. Where do the rollers go? Do they roll inside or outside? I noticed there is a cutout on the right and left sides of the opening where the glove compartment is. Can't quite figure out if the rollers need to go into those cutouts, or if the cutouts are there as a latch.
If I could ask someone a favor to check their Discos and let me know how the glove compartment is installed it will be very much appreciated.
Sorry for the trouble
Thanks in advance
Al
2003 D2 SE7
Old Oct 13, 2012 | 07:35 PM
lr2001silver's Avatar
Banned
Al, the rollers go inside those cut outs your referring to. Also be careful they do seem to get brittle so dont force them or they will break right off.
Old Oct 13, 2012 | 08:10 PM
aguison's Avatar
Thank you lr2001silver I'll give it a shot
It looks like I have to hold up the spring loaded rollers to get them in. Could be a challenge
Old Oct 13, 2012 | 08:45 PM
Banned
Yes just be careful with them
Old Oct 14, 2012 | 12:28 PM
aguison's Avatar
Default Glove compartment
Thanks. Successfully put back the glove compartment.
The easiest way is to first bolt in the hinges, just hand tighten. Then with both hands lift the spring-loaded rollers and guide them through the cutouts until they slide in.
Then play with the glove compartment adjusting as necessary for a good fit and locks engage properly.
Al G
2003 D2 SE7
m1964
LR2
Oct 31, 2010 01:28 AM
rtwarshel
Nov 16, 2008 10:49 AM
dbs600
Apr 16, 2007 01:18 PM
gtf8326
Jan 31, 2007 02:00 PM
