00 DII 72K Gushing water sound near glove compartment
Old Jan 27, 2007 | 10:41 PM
gtf8326's Avatar
5th Gear
Default 00 DII 72K Gushing water sound near glove compartment
Each time I accelerate or rev up in neutral, I would hear a very noticeable sound near the glove compartment. The sound is like water gushing through a water drain pipe...could this be something to do with the heater? I don't see any leaking fluids / coolants. Thanks for your help.
Old Jan 28, 2007 | 11:57 PM
xadamx's Avatar
Default RE: 00 DII 72K Gushing water sound near glove compartment
you either:
-have a coolant leak
-need to fill your coolant to fill level
Old Jan 29, 2007 | 02:02 PM
I agree, your engine is low on coolant, hence air is trapped in the engine which will make that noise and can overheating of the cylinder heads as well.
Need to have someone do a pressure test on the coolant system to find the leak and fix it. Could be head gaskets or some external leak.
Mike
Old Jan 30, 2007 | 09:02 PM
gtf8326's Avatar
5th Gear
Thank you both.
Old Jan 31, 2007 | 02:00 PM
Make sure you find where the coolant is leaking from, and use only the orange DexCool coolant.
Mike
aguison
Oct 14, 2012 12:28 PM
m1964
LR2
Oct 31, 2010 01:28 AM
rtwarshel
Nov 16, 2008 10:49 AM
Willie 00D2
Apr 17, 2007 12:12 PM
dbs600
Apr 16, 2007 01:18 PM
