NEED HELP! Radio / water problem
Old May 28, 2005 | 05:43 PM
gillboy's Avatar
Default NEED HELP! Radio / water problem
I have a water leak that comes in through my rear view mirror on a 2001 Disco when I park facing downhill. I know, so don't park downhill nitwit!.....
After a large rain storm, I got in the car to find it pretty wet, including the dash and the radio console. The radio hasn't turned on since. The fuse isn't blown, and this has happened before, and in the past it has turned on again on it's own. Is there a reset, or is it fried?[]
Old Nov 8, 2008 | 01:39 AM
Disco SoccerMom's Avatar
Default RE: NEED HELP! Radio / water problem
Just wondering if anyone has an answer to this problem. This happened to me today.
Old Nov 8, 2008 | 03:56 PM
It is either a clogged/disconnected sunroof drain or a leaking windshield seal.
Is your radio not workng now too? Or just the leak?
Old Nov 8, 2008 | 05:52 PM
LRScott's Avatar
Well it may or may not turn back on, most radios and anything with a circuit usually have ways of sensing when something is going to short out and will often times disable itself for protection. Cell phones do this when you wash them. But, sometimes the device is to late and its FRIED... depending on how wet it got... it is still possible that there is water in the radio even days after it got wet... if i were you i would pull the fuse out, to keep the radio from getting anymore power... when an electronic device does not have power and it gets wet... its fine. (which is why you can shove your computer keyboard in the dishwasher let it dry out and then plug it back in and it still works...) . If you can, take the radio out and let it dry in your house, chances are it might turn back on, after all it is a rover radio. is it? . and get that leak fixed asap (obviously lol).
Old Nov 8, 2008 | 07:49 PM
Sunroof leaked, had someone fix that problem for me after finding the solution on here. When I cranked the truck, the radio just made a loud static crackling noise like it's on AM. It will come on, but will not stop making that noise.
Old Nov 8, 2008 | 08:19 PM
So after you start the truck the radio sounds like static? No audio only noise?
Old Nov 9, 2008 | 05:42 PM
Yes it is extremely loud static and popping. If you scan it goes to a station you just can't hear it. You can change from FM1 FM2 and CD changer, but still only the same noise. I just turned it off and now am driving in silence.
I know if I take it to a shop they'll just say, 'lady you need a new radio." But maybe if you guys have ideas as to what the problem is I can sound somewhat informed when I go.
Old Nov 9, 2008 | 05:58 PM
"Lady, you need a new radio"
Sorry, but I think that is the case. Your is fried.
www.roverlandparts.com has good used ones, also check e-bay.
Otherwise you can go to BestBuy or Circuit City and buy a good aftermarket radio.
Old Nov 9, 2008 | 06:00 PM
Forgot to mention, if you buy another LR radio you can change it yourself as long as you have the "radio removal tool" which you can buy from www.atlanticbritish.com
Old Nov 10, 2008 | 07:46 AM
Thanks so much! Do you think the speakers are messed up too or just the radio?
