Need ideas on timing chain problem
Old 08-09-2021 | 01:48 PM
me 2's Avatar
I did change the fluid out in the trans about a month ago. Pretty sure it’s not trans fluid. Stumped
Old 08-09-2021 | 02:22 PM
Richard Gallant's Avatar
@me 2 just had a thought check the fan clutch, there is not much in there though. But it could have failed
Old 08-09-2021 | 03:45 PM
me 2's Avatar
Well I’m actually back in looking at the chain. Which way should I be turning the crank to set tdc? Is it clockwise?
Old 08-09-2021 | 03:58 PM
me 2's Avatar
Timing is perfect
Old 08-09-2021 | 04:01 PM
me 2's Avatar
Also front main seal looks properly seated.
Old 08-10-2021 | 01:48 AM
Brandon318's Avatar
The front main seal looks a wee bit proud of where it should be. Doesn't look like your leak, but just noting that in case something else comes up down the road.
Is that a crack in the oil pump gear at 1 o'clock?
Old 08-10-2021 | 02:03 AM
The Deputy's Avatar
I'm sorry to say...but...you went about this all wrong. To find a leak...it's best to clean area and then run it. Not disassemble it.
The running issue could be tune-up related, check wires.
Brandon318 (08-10-2021)
Old 08-10-2021 | 08:47 AM
me 2's Avatar
Man, I spent like 10 mins inspecting all the gears, it’s a brand new gear too.
honestly I tore it back down to make sure the timing was straight, second guessing myself but I feel good knowing it is now.😁
Old 08-10-2021 | 10:08 AM
me 2's Avatar
Well started back up and seems to be running good. There is a drip coming from behind the crank pulley, guessing the new parts and new oil are hopefully going to come together
Old 08-10-2021 | 10:41 AM
me 2's Avatar
Actually leaking consistently 🙁
Quick Reply: Need ideas on timing chain problem
