Need some serious Direction. Im a new member as well!
Old 11-27-2023, 11:10 AM
mollusc's Avatar
You can't "rip out" the immobiliser, but it can be disabled once you're able to get into the vehicle. Same with superlock.
If you're planning on keeping the truck, you'll need to invest in a Rover-capable code reader/programmer that can change these types of settings.
How is the battery charge? Rovers do weird things when the voltage is low. The fact that you're hearing the actuators click when you turn the key in the door indicates that the link pin between the key barrel and the lock mechanism is intact, which is a big plus.
Old 11-27-2023, 11:29 AM
greisinb's Avatar
What does your battery voltage look like? You might have to figure out some creative way of finding that out from underneath the vehicle (and to hook up a charger, if that's the case) seeing as how you can open the door to unlatch the hood. As others have said, if you need to break a window break the rear quarter window- now you have a good excuse to turn it into a "gullwing" access panel to get in the rear cargo area (look it up on YouTube, it's pretty cool).
Old 11-27-2023, 02:43 PM
Harvlr's Avatar
The only place I can think of to check power or connect a charger is at the starter.
Old 11-27-2023, 07:34 PM
Extinct's Avatar
Received 1,487 Likes on 1,055 Posts
Battery voltage only helps if you are using the dash switch or key fob to open the truck. If the key cylinder turns and the rod is in place it will unlock the drivers door. You can drill out the lock cylinder and turn the lock actuator to unlock the drivers door. You can break the quarter window in the rear door (smallest window on the truck and easy to replace with a door frame replacement).
Old 11-28-2023, 04:28 AM
Dervish's Avatar
Or the trailer plug.
Atleast the 13 pin socket with all connected has live positive.
Don't know what kinda sockets are in use in the US.
Old 11-28-2023, 08:59 AM
MasonJ's Avatar
Originally Posted by redrover75
You can jam a rod, coat hanger in the window frame, it will tear up the door seal, but that may be the cost of doing business.
Windows are easy to replace, cheap too. Dont feel bad if you go that route, you probably have a failed regulator anyway that will need replacing too.
Love the color.
I’m going to try one more thing ( going in the rear license plate holes and trying to snag the rear hatch lock mechanism ) before I try this. Thank you!
Old 11-28-2023, 09:01 AM
MasonJ's Avatar
Love the color.
I’m going to try one more thing ( going in the rear license plate holes and trying to snag the rear hatch lock mechanism ) before I try this and then a coat hanger in the door frame. Then it’s raining glass!
thanks for the love on the color. It’s growing on me. But I think it’ll look nice decked out.
Old 11-28-2023, 09:02 AM
MasonJ's Avatar
Battery is fine. I can open the hood from the front grille with my hand. Battery is full.
Old 11-29-2023, 08:02 PM
MasonJ's Avatar
Love the color.
i got in by going through the license plate holes and snagging the rear door lock!
The following 7 users liked this post by MasonJ:
Dervish (11-30-2023), hasullivan (11-30-2023), JohnZo (11-29-2023), mollusc (11-30-2023), Richard Gallant (11-30-2023), sdtimb (12-02-2023), T-rex (11-30-2023) and 2 others liked this post. (Show less...)
Old 11-30-2023, 09:00 AM
sqlbullet's Avatar
That is great news.
The following 2 users liked this post by sqlbullet:
MasonJ (11-30-2023), Richard Gallant (11-30-2023)
Quick Reply: Need some serious Direction. Im a new member as well!
