Need To Take My Ownership To The Next Level
OK, so I am still fighting my misfire problem. Taking the purge valve out and plugging the TB didn't make a difference.
I want a really good diagnostic tool, with the ability to program stuff, like stereo, security, key fobs, etc. Part of my problem is I do not have a good tool to work on my Landy's.
Can I get something like this for around $500 US?
I am a committed (but not insane) Discovery 2 owner.
Thanks for all your help,
Lisa
Lisa
I just got a Foxwell NT520 pro. Haven't had time to see all its capabilities yet, I'll just see what it can do as I need it but, I hooked it up and it does access all systems including ABS, BCU and transmission, etc. It can activate certain functions like the ABS pump for bleeding brakes and it says it can program a key, reset adaptive values, change a vin, etc. but I can't say if or how well it will do anything yet. I paid 210.00 direct from Foxwell b/c it came with 2 free manufacturers' software. I couldn't justify an expensive tool that only covered 1 make or model. I got the LR/Jag which covers just about every model. Haven't gotten the 2nd free mfgr. yet b/c it's Chinese new year and apparently they shut down for a week.. Each additional car company's software is 60.00 and goes on a micro sd card. They have a support request link so if you need it to do something that it can't, supposedly they'll work on a solution for you.. I'll post how well it works (or not), as I use it.
on
When working on your own Land/Range Rovers, Diagnosing Land/Range Rover problems is MUCH easier using a Hawkeye, Nanocom, or similar. As far as I know, and I have both these scanners, the only main difference between these two, is that the Nanocom will program for USED key fobs, while the Hawkeye will not. They both will program NEW key fobs. Otherwise, they both do basically the same thing.
