Need Torque specs for 96 Discovery 4.0
Please help. My 96 Discovery is in the shop with the engine torn down for a top end rebuild and my mechanic says he needs the torque specs before he can reassemble. If anyone has a spec sheet they could share with me, or can tell me where to find the info online, I'd be very gratefull.
My only other choice is to buy the shop manual, and at $150. US, that a lot to pay for a book I'll hopefully never have to refer to again.
Thanks.
Thanks.
RE: Need Torque specs for 96 Discovery 4.0
Yes, the torque settings as found in the shop manual. This guy knows what he's doing. He's a pro mechanic to whom I've entrusted the wrenching on all my vehicles (from vintage VW Beetles and Ghias, to Corvettes, to new Jeeps and Toyotas) and have never been disappointed with his work. He's just never worked on a Land Rover before and instructed me to order the manual before he tore it down, but after just spending over $600 on parts, I was hoping to find the torque settings without having to pay an additional $150 for the book.
-MC
-MC
Coupling shaft to mainshaft 42*Nm
Filler tube to sump 68 Nm
Gear change lever to gearbox 25Nm
Cooler pipe adaptor to gearbox 42 Nm
Securing screws - clutch F 10Nm
Securing screw - parking pawl 10 Nm
Securing screws - pump 10Nm
Intermediate plate plugs (M20) 50Nm
Intermediate plate plugs (M14) 40 Nm
Bell housing mounting bolts 46Nm
Governor mounting screws 10 Nm
Extension housing bolts 23 Nm
Control unit mounting bolts 8Nm
Sump plug 10Nm
Mounting screws for sump 8Nm
Drive plate to converter 39*Nm
Gearbox to engine 42Nm
Strut (threaded end) 42Nm
Bottom cover to converter housing 9 Nm
Cover - converter housing 9Nm
Drive plates to crankshaft adaptor 40*Nm
Adaptor to crankshaft 84 Nm
i have no idea if these numbers will help anymore....just found them randomly on a car test site...they were for a 93 range rover country 3.9 auto tranny....i would imagine the numbers are the same..........thats all i got for you tho....
Sump plug 10Nm
I believe it can help everyone with repair issues. At the following home-page you will find a PDF file with the Discovery's workshop manual:
http://www.clubelandrover.com.br/gar...coWorkshop.pdf
This page is in portuguese, but the workshop is in english.
By the way, if anybody has a similar file for the owner manual for the 97 Disco 3.9, please let me know.
