New Battery, Good Alternator, Need to jump every time. Ground or Parasitic Drain?
Old Aug 19, 2020 | 04:51 PM
  #21
mln01's Avatar
Originally Posted by Best4x4
Also clean the starter terminals.
Wow. This brought back memories.
Over 40 years ago that was the problem with my first car, a '65 Mustang. I just loosened the terminal on the starter and scratched around a little on the mating surfaces of the cable and the starter. There was no visible corrosion, but the connection was somehow not good. Solved the problem.
Where are you measuring the 12.6 volts when not cranking? If you're getting the reading from the battery posts you might want to check downstream, at the starter perhaps. A lower reading at the starter would confirm a connection problem.
On the other hand the problem sounds like insufficient amps making it to the starter and not low voltage, which again indicates a bad connection (or two, or more). And just like with my Mustang, the connection can look fine and still be wonky.
Old Aug 19, 2020 | 06:14 PM
  #22
Best4x4's Avatar
Yep when I got my rusty but trusty 97 XD it was weak starting and I had ECU voltage faults, and I didn't even have decent voltage at the OBD2 Port. I cleaned all the battery terminals, no change, cleaned the ground to the frame (helped), cleaned both small and larger terminals on the starter (fixed slow starting), and eventually tracked the ECU issues/OBD2 low voltage down to a completely rusted ECU PCB..... Slapped in another non rusted ECU and it's ran like a champ ever since. Starter terminals looked ok, but once cleaned up it was night and day. Original starter is still in place as well.
Old Aug 20, 2020 | 12:25 AM
  #23
JUKE179r's Avatar
Originally Posted by stxscott
Similar problem on mine was a bad ground (-ve to engine). It didn't look bad at all but after cleaning it up my starting problem was resolved. It was so bad the engine tried to ground via the brake cable. Got so hot it welded itself. As these vehicles get older it's always good maintenance to check ground connections and clean them up. Trust me - replacing the handbrake cable is a bugger of a job.
I’ve read about that same grounding problem at the firewall from other Disco 2 owners.
As a safety precaution for me I wire brushed that grounding area at the firewall, the rear grounding point on the intake manifold and wire brushed the webbed grounding strap. I also added an 8” length of 10AWG cable as an additional ground to the firewall from the coil pack’s top mount bolt.
You can’t be too careful...
Old Aug 21, 2020 | 05:20 PM
  #24
boston4's Avatar
Starter replaced - issue appears to be resolved. Thanks to everyone who weighed in - really appreciate it!
Old Aug 24, 2020 | 10:04 AM
  #25
First time Disco fan's Avatar
Originally Posted by ahab
If you're vacationing near Philly perhaps I can help? Although that sounds like an oxymoron! A failed starter is hard to come to terms with however if you've ruled out everything else I suppose it could be a possibility. I've never seen one fail in this manner but I certainly haven't seen everything, either. Since it's been starting with a jump, what happens if you try and jump start it from a non-running car, just a second battery? Connected in parallel this would double your amps but probably still not come close to what an alternator is providing.
What if it does start without the donor car running? What needs fixed? I have to jump her every day!
Old Aug 24, 2020 | 11:24 AM
  #26
boston4's Avatar
Here are your troubleshooting steps:
1. Head to a local parts store and have them check your battery and alternator. Perhaps there's a bad cell in your battery and it doesn't have enough CCA to turn the engine. Could also be an issue if you're traveling in really short trips that don't provide enough time for the battery to charge back up to a level that can restart the truck.
2. If the battery and alternator are OK, check your grounds at the block and body as well as the battery terminal connections - make sure they're clean and tight.
3. If the grounds and terminal contacts are good and clean, check your starter contacts - make sure the battery is disconnected for this.
4. If issue is still present after the steps above, replace starter.
I ended up needing to replace the starter.
Nov15
Jan 10, 2024 05:01 PM
starcraft1
Aug 15, 2019 11:29 PM
gpelite
Mar 2, 2016 05:56 AM
xargon15
Feb 4, 2015 08:02 PM
J P Cook
Jun 4, 2014 09:40 AM
