New D2. First lengthy inspection after buying sight unseen
Old Apr 13, 2020 | 09:19 PM
  #21
Best4x4's Avatar
I used to run that 20/50w Valvoline oil in my 94 RRC until it got very hard to find, and then I found out about the 15/40 Rotella which I personally like better. It's not as thick as the 20/50w and it's SO much easier to find basically anywhere.
Old Apr 14, 2020 | 08:50 AM
  #22
NewToTheTwo's Avatar
Originally Posted by Extinct
Good oil, very expensive relative to the diesel oil, .
Both good points and I know I can get the Rotella at WallyWorld........I'll have to consider switching back
Old Apr 14, 2020 | 01:53 PM
  #23
Jason Feuerstein's Avatar
The factory radio is nothing special and I would bin it for something more modern. Make sure it has pre-amp outputs if you do.
Also great to see your engine has preserved the underside of the vehicle with a layer of oil. I think that's why my Disco is as rust-free as it is.
Like many on this forum, I use Rotella 15W-40, and you can't beat the price versus the level of detergents in it. Dump some Seafoam in when you change it.
The other thing I would do is take a wire wheel to that rust on the frame and then spray paint it with a rust converter immediately. I then spray the frame with Fluid Film every winter to protect it from road salt. It's really something you need to stay on top of.
Theshire4x4
ROAMING WITH FRIENDS
Apr 24, 2019 12:01 PM
Theshire4x4
Sep 23, 2018 12:00 PM
Theshire4x4
Feb 11, 2018 04:07 AM
Daedrix
Jun 1, 2016 10:13 AM
chasej318
Sep 21, 2012 03:45 PM
