New D2 New Problems
Old Jul 24, 2017 | 07:25 PM
  #21
No Doubt's Avatar
Originally Posted by mogarchy
Can someone help interpret this failed test? It is from my BlueDriver ODBII scanner. Thanks!
If it's helpful, I converted the HEX to Decimal and it comes out as:
Value: 1002
Max: 1000
It suggests that your pre-cat O2 sensors are old...but...if you clear all codes and let your Disco warm up at idle for ~~30 minutes and *then* run your diagnostics, numbers that close might turn up "acceptable".
Old Jul 24, 2017 | 08:03 PM
  #22
mogarchy's Avatar
Cool, thanks. I will put them on my list to replace in the near future. I did this test just after parking and had driven for about 20 minutes in 95 degree heat.
The good news on that front is my coolant temp, the original reason for getting this scanner, is staying below 200 after installing the 180 thermostat and fixing my coolant leaks. I've bled the system 3 times now and *almost* have no waterfall sound left, maybe 4th time will be the charm.
Old Jul 24, 2017 | 08:12 PM
  #23
Luckyjayb's Avatar
go with walker o2 sensors if you need them. Best ones for our rovers
Old Jul 24, 2017 | 09:41 PM
  #24
No Doubt's Avatar
Those are great O2 sensors (especially for gas mileage), but if your goal is to not have code failures the cheapo knockoff O2 work: Brand New O2 02 Oxygen Sensor Upstream Front Pre-Cat for Land Rover SG338
Pete Driscoll
Apr 27, 2016 06:29 PM
petedriscoll23
Mar 27, 2016 03:03 PM
Frank4
Mar 21, 2014 05:21 AM
formel3
Jun 13, 2013 12:33 AM
Hyakku
Jan 9, 2011 11:32 AM
