new engine coolant
Old 02-09-2009 | 05:27 PM
airborne18d's Avatar
Default new engine coolant
Can anyone recommend a different coolant, other than the factory recommended, for my Discovery? I drive from MS to NC fairly regularly and also take the truck off road frequently.
I ask because my truck is running in the upper normals at rest and can raise border on the red after a long drive but cools during movement. My fan is working and all the hoses are solid.
Old 02-09-2009 | 05:40 PM
Default RE: new engine coolant
Well the coolant is not the problem for this.
I use Peak Global Lifetime 50/50 premixed.
Is your coolant level full?
If so look into your water pump or a dirty/clogged radiator.
Here is where I would start, do a complete cooling system flush.
If that does not fix it then replace your water pump.
Old 02-09-2009 | 07:13 PM
llPANCHOll's Avatar
ORIGINAL: Spike555
What he said
Old 02-09-2009 | 08:50 PM
okdiscoguy's Avatar
on top of that, pop off the clips holding the radiator. If you have never done this, I'll bet you have some junk between the rad & conderser.
Check your water pump pulley/back of the belt for glazing. Might be failing bearing in the water pump or tensioner going bad.
Don't run it to the red, or you may pop the engine. Aluminum doesn't like heat.
Old 02-09-2009 | 11:13 PM
Tvdmtac's Avatar
Listen toeveryone on the cooling issues, just so you knowmy new engine for my 2000 Disco II only cost me 7K to get installed and fixed...... NEVER RUN A LAND ROVERHOT!
Old 02-10-2009 | 06:16 AM
llPANCHOll's Avatar
Ouch!
Old 02-10-2009 | 09:19 AM
jycsalas's Avatar
I've heard from a reputable source (Disco Mike) that if your temp sensor gets ANYWHERE near red its almost too late. He says the temp sensor is slow to give accurate reading and that if its near red, it has been TOO HOT, TOO LONG and there's a good chance you're toast
if its EVER above normal....its IMPORTANT to check water pump, coolant level, etc...
... so bottom line, after your temp is back to normal...check your oil for coolant, and check head gaskets.
Old 02-10-2009 | 10:44 AM
ORIGINAL: airborne18d
You seem to be rather quiet today, did you not like the suggestion, which, by the way, are right on the money. Do not switch from Dexcool and fix, what is the real problem.
Mike
Old 02-10-2009 | 12:38 PM
okdiscoguy's Avatar
Mike- you running Purple Ice still?
Old 02-10-2009 | 03:54 PM
Yes, as are a number of my friends.
Quick Reply: new engine coolant
