New Front Cover Gasket Needed?
I rebuilt my oil pump (which had a cracked gear) a couple of weeks ago to help solve my low oil pressure problem. After getting everything back together, I found that my oil pressure is still low at hot idle.
I have pulled my oil pan again to start working on replacing the main and rod bearings. It looks like I am going to have to take the front cover off again to get to the bolts on the forward bearing. Do I need to replace the gasket again if I do pull the front cover? Obviously, if it does rip, I will replace it. But what it comes off without ripping? Will it still seal up okay if I reuse it?
Same question for the oil pan gasket. Being rubber, I think it is ok to resue it.
Thanks! This forum has been been a lifesaver.
outdoor7or24
12-22-2014 09:31 PM
bcolins
06-29-2013 09:25 PM
Marni
06-22-2013 05:04 PM
crystalsky8379
09-01-2010 08:11 PM
