New Front Cover Gasket Needed?
Old May 10, 2015 | 01:50 PM
lrjon's Avatar
Default New Front Cover Gasket Needed?
I rebuilt my oil pump (which had a cracked gear) a couple of weeks ago to help solve my low oil pressure problem. After getting everything back together, I found that my oil pressure is still low at hot idle.
I have pulled my oil pan again to start working on replacing the main and rod bearings. It looks like I am going to have to take the front cover off again to get to the bolts on the forward bearing. Do I need to replace the gasket again if I do pull the front cover? Obviously, if it does rip, I will replace it. But what it comes off without ripping? Will it still seal up okay if I reuse it?
Same question for the oil pan gasket. Being rubber, I think it is ok to resue it.
Thanks! This forum has been been a lifesaver.
Old May 10, 2015 | 02:08 PM
dusty1's Avatar
Might as well get a timing set..New chain, sprockets, gasket.
That thing is paper and I doubt I would be willing to reuse it
Old May 10, 2015 | 03:16 PM
lrjon's Avatar
Yep, I did the chain and sprockets 2 weeks ago when I had it apart the first time.
Old May 10, 2015 | 05:21 PM
drowssap's Avatar
If the dont rip use a thin coat of black RTV.
Old May 11, 2015 | 03:00 PM
jfall's Avatar
Replace the main bearings on the crank to increase oil pressure.
Use 20W- 50W oil in the summer.
Not synthetic.
outdoor7or24
Dec 22, 2014 09:31 PM
tmtegt
Mar 20, 2013 07:31 AM
crystalsky8379
Sep 1, 2010 08:11 PM
