New Guy--Need Some Help and Ready to Learn
In May of this year I bought a '04 Disco with 45k miles. Since that time, I've put just over 3k miles on the truck. In recent weeks, I've noticed two separate issues that could be minor--but could also be pretty major problems. Before I address the problems, I will say that I have read the advice on this board extensively and am going to take a couple of actions this week.
1. In the past week and a half I've been getting intermittent 3 Amigos. The lights come on sometimes when I start the vehicle, sometimes after I drive for a few miles, and often not at all. I do not have a code reader.
2. I've also noticed a coolant leak (who would have guessed) in recent days. The leak is very small, but I can smell the coolant when the vehicle gets to running temp. I'm going tomorrow or Wed to get a pressure test.
Not sure if anyone has any advice, hints--but anything would be appreciated.
Ok, so I assume that I'm going to have to drain the coolant in order to replace the heater hose. Correct? I've read the instructions and consulted the RAVE CD, so I'm pretty comfortable with that. My next question comes to re-filling the coolant. I've read the DexCool/Green Coolant debate. I thought DexCool was orange, but my coolant is Pink. I just want to confirm that once I flush the system that I'm good to refill with any OAT coolant.
If I can get my camera to work, I'll post a couple pictures when I get home this evening.
If you have to replace hoses, go ahead and flush the radiator and re-fill with the factory-recommended coolant. If the vehicle is new to you, I'd assume it has never been done. Also proceed with the 60k service in the "sticky" posts.
You'll need a shop with the correct equipment to give you the brake codes. Could be an easy fix or require rebuilding or replacing your ABS unit. Atlantic British has a rebuild kit that would be my first try ~ $90.00 as I recall.
colson2003
01-31-2015 02:07 PM
Twin Turbo 350
01-08-2011 05:48 PM
m4ver1ck
07-22-2009 08:03 PM
