New hub installation: Does everyone else have a 360ft/lb torque wrench?
Old Feb 9, 2020 | 06:18 PM
Brandon318's Avatar
Default New hub installation: Does everyone else have a 360ft/lb torque wrench?
So about this torque spec on the front hubs... I know a lot of you change them out yourselves. Do you all happen to have torque wrenches capable of that spec? Or just educated-guessing it?
To buy a torque wrench like this for one purpose seems like way too much of an expense. Rentals aren't available that high, and even Harbor Freight's highest-spec offering only goes to 300.
Old Feb 9, 2020 | 06:25 PM
I have an impact and I’m an expert at knowing the sounds of the proper uga-duga for the torque spec
Old Feb 9, 2020 | 06:56 PM
SundayFunday's Avatar
I just use a 1”drive with a 5’ breaker bar
-I find the punch depression in the safety cover seems to line back up moreless indicating its back in similar position.
Old Feb 9, 2020 | 07:00 PM
Best4x4's Avatar
I tighten them up with the wheels back on the ground without the center cap. I use a long 1/2 breaker bar and new nuts and I tighten them and punch the nut so it won't walk loose. Have yet to have any issues with that method.
Old Feb 9, 2020 | 07:38 PM
Extinct's Avatar
3/4" drive harbor freight set, here. 200lb man on 18" pipe equals 300 ft lbs. Close enough.
Old Feb 9, 2020 | 08:00 PM
11chuck's Avatar
German specs. Gudentite
Old Feb 9, 2020 | 10:18 PM
Rlozano's Avatar
I’ve worked on mine quite a bit. Although I do have the large torque wrench on board I go as tight as my impact Gun goes using my co2 tank at 95 lbs. ido this so I can remove in case of a brake on the Trail. Been wheeling for years and never had any issues. The book also calls for loc tight but I skip that and use never cease instead.
Old Feb 10, 2020 | 01:51 AM
JUKE179r's Avatar
I was looking into this also since I will be replacing both front hubs soon.
Luckily I found a professional hire/rental company that has a digital torque wrench that goes from 250 to 700 for £52($67)/day.
Old Feb 10, 2020 | 08:06 AM
CollieRover's Avatar
Get genuine nuts, the ones I got were 36mm and could not be tightened with the wheel on, as the socket would not fit.
The best advice I got was to get a 3/4” Breaker Bar. That with a 6’ length of lead pipe do the job for me.
I was able to get the old hub off with a claw clamp and a breaker bar. That was not easy.
Use the sensors that come in the hubs if you can.
Old Feb 10, 2020 | 08:20 AM
Good find. I hadn’t thought of that.
