New Key FOB for D2 - Options to buy
Old Nov 27, 2014 | 11:35 PM
Rover_Hokie's Avatar
Default New Key FOB for D2 - Options to buy
My apologizes if this has been covered before, I feel sure it has, but I cannot located it. As fate would have it, my driver's door lock actuator failed shortly after I bought my used D2 some 6 years ago now. I finally got around to replacing it a couple months ago, and shortly after lost my last key fob. Luckily when I lost my first key fob I had two spare regular keys made to fit.
I would like to take advantage of the door actuator now, so I guess I will be biting the bullet to buy a new key fob and have it cut and programmed. What am I looking to pay at the dealer and are there any other options?
Old Nov 28, 2014 | 08:16 AM
dusty1's Avatar
Just need to find someone with a programmer like hawkeye or nanom. Not 100% sure which ones actually do it
Sadly I have considered buying one of those just to do the same thing you're doing
Old Nov 28, 2014 | 10:38 AM
Lowest Bidder's Avatar
Someone correct me if I'm wrong, but if I remember correctly you can only program a new keyfob with Hawkeye if you have in your possession at least one keyfob already programmed and working. It may be different with other programmers.
Old Nov 28, 2014 | 12:52 PM
acg's Avatar
acg
The Nanocom is easier to program a key fob replacement. All you need is the key code (6 digits/letters). I did it with a fob replacement which I purchased from Paul Grant. Here is an example of the Nanocom re-programming procedure:
I read somewhere the Hawkeye programming process is a little more complicated and needs the entire bar code key string.
Old Nov 30, 2014 | 02:50 PM
G150driver's Avatar
So, where does one find this six-digit code? Obviously, it's supplied with a new key. But, is it printed on the circuit board inside the key by chance?
Old Nov 30, 2014 | 03:09 PM
acg's Avatar
acg
It is usually a small printed label which is pasted to the internal circuit board inside the key fob. You will have to make sure the label is still there when you buy a used fob from the seller. Here is a picture example:
Switch Button for Remote Key Fob Land Rover 75 Discovery 2 Disco HSE TD5 LR | eBay
Old Dec 30, 2014 | 01:39 PM
dusty1's Avatar
I don't suppose I could use anything other than a d2 key?
Suitable for Land Rover Discovery 3 4 Full Key Fob Remote with Chip and 433MHz | eBay
like Chinese lr3/4 ones....?
much cheaper
Old Dec 30, 2014 | 01:56 PM
Did a little quick searching, the first hurdle is matching the frequency and it seems there are two choices for the DII 315 mhz or 433 mhz. If you have a 433 then you are past the first step of the frequency match. Then it would be on to the programming.
Before you ask I have yet to find a way to tell short of opening a key and seeing if it is printed inside.
Old Dec 30, 2014 | 02:12 PM
dusty1's Avatar
thanks. that company has both 433 and 315. and has code on packaging. so it might work
Old Dec 30, 2014 | 02:35 PM
You ordered a nanocom right? If you did I guess it would just be a $50 gamble to be the guinea pig. If it works I'll be ordering a pair of them though.
