new lift and tires installed
Looks like how it should have came from the factory. Smart choice the Medium duty springs, especial since you're not adding extra weight.
Post your front and rear gained height measurements (wheel arch to center wheel hub) in the thread titled "share your measurements" so other forum members can see your progress.
Don't worry about crossmember spacers or extended brake lines you don't need them if your not flexing constantly off road.
How much fuel was in the tank when you took the garage door clearance picture?
The additional weight of a full tank of gas could give you the clearance to get in the garage. An empty tank might not give you the clearance.
