New to me 2003 D2 has water leak at right rear corner.
Old Dec 26, 2016 | 06:12 PM
bcolins's Avatar
Default New to me 2003 D2 has water leak at right rear corner.
I opened the back door of my 03 D2 today after some recent rain and noticed I had wet carpet in the right rear corner. Looking up I could see it was running down the right rear interior trim panel. Doesn't appear to be leaking from the rear door,....so, thinking that means its either the sunroof or the right rear upper "safari" window.
Any thoughts on this?
BC
Old Dec 26, 2016 | 06:25 PM
LR03NJ's Avatar
If it is from the rear right upper window you can reseal it with clear silicone. If you use the rear sunroof often, replace seal or check if the drain is clogged. If and if you don't open it, seal it with clear temporary/removable silicone caulk. So in time you have time to check it, just undo the caulk.
Dap 18351 Seal N Peel Removable Weatherstrip Caulk 10.1 oz Clear
http://www.essentialhardware.com/dap...FYZMDQodEtUH7A
Paul Grant
Sep 22, 2011 05:12 PM
losinov
Dec 3, 2010 09:20 PM
ezlnh8u
Jun 14, 2009 11:37 AM
danluttrell
Nov 25, 2007 02:03 AM
Lighting90
Off Topic
Feb 15, 2005 07:31 PM
