new potential lift/ springs
Old Feb 21, 2017 | 01:28 PM
wynhd's Avatar
Default new potential lift/ springs
Hello,
I currently run stock height suspension on my 02 DII. I have replaced the original shocks with stock height TerraFirma shocks, thus far no complaints with steel bumpers (front and rear). I now have acquired and installed a Safety Devices Rack. Am I taxing the suspension? I located a set of Britpart coil/ springs that claim 40mm (1.5") lift for $290 OBO new. Are they a good coil/ spring to use. I am also running stainless brake lines that are plus 2" so brake lines shouldn't be an issue. Model of Britpart coil/ springs is DA4197 and DA4199. I am not trying to be cheap by any means, however don't want to overpay.
Old Feb 21, 2017 | 01:48 PM
zoltan7's Avatar
I cannot weigh in on the springs, however I can tell you that you aren't taxing your suspension.
If you lifted 1.5", you still wouldn't need the +2" SS lines (stock would be fine). Unless you went with 33" tires, then you'd be close enough to warrant the extra length.
I might be wrong, but you can get a TF spring set for roughly the same price right? Might be a good chance for you to check shock towers and what not to make sure those are okay (they typically rust)
You might want to also get a TF steering damper and maybe some upgraded steering rods and such. Just helps a bit for future endeavors
Old Feb 21, 2017 | 02:30 PM
wynhd's Avatar
@Zoltan, the 2" lines are already on the disco, they were cheaper than standard length and if i wanted to add a lift down the line, they were already done. And you are correct about the TF spring set, on Lucky8 I believe are within $20 of each other. I have been told I can run the same shock on the front with new springs and the rear would need +2" which I can do. My shock towers are in great shape, was a Texas rover and now resides in SoCal, away from the beach.
Old Feb 21, 2017 | 03:13 PM
Frank4's Avatar
Frank's obligatory lift thread answer:
If you are going to do a lift, consider the RTE 3". Sounds like you are an accessory guy, I am as well. Down the road you might think about bigger tires, the 3" gives you many more options over the 1.5"-2" coils.
Old Feb 21, 2017 | 06:25 PM
wynhd's Avatar
I feel like I should've replaced the coils when I did the shocks, however my indy mechanic didn't feel it was necessary. I like the stock look and have seen some nice looking rovers lifted. I get what I feel is amazing MPG, 16 city/ 19 hwy, I don't speed and I am assuming that plays a role. I have a feeling if its not kept stock height, MPG will suffer.
Old Feb 21, 2017 | 06:27 PM
Luckyjayb's Avatar
Terrifirma is a britpart company if that helps you any
Old Feb 21, 2017 | 06:56 PM
Frank4's Avatar
Ha, yeah. Your MPG will suffer.
Old Feb 21, 2017 | 08:52 PM
Twix's Avatar
Your MPG won't suffer that much on the highway with a bit of lift. Your rack is going to be the biggest killer. There are coils out there for extra loads, but stock heights
Old Feb 22, 2017 | 09:00 AM
wynhd's Avatar
Heck, maybe I'll part with the rack and just lift her some or get new stock height HD coils. Most likely give Eric @ Lucky8 a call to see what he can do for me.
jamieb
Apr 2, 2016 10:33 AM
rchrd0413
Apr 22, 2014 02:18 PM
Lincoln Tarantino
Apr 4, 2012 02:01 PM
nickm347
Jun 23, 2011 12:59 PM
fri3daz3
Aug 18, 2008 09:22 PM
