new problem ?
Old May 19, 2015 | 06:58 PM
martin12's Avatar
Default new problem ?
Little back story put new y pipe and 4 new o2 sensors on, everything good for a month or two. Code p0150 and p0174 been popping up, as well as a new one p1174. At a light or idle in gear it spits and sputters like it wants to die. I figure the p0174 codes ( bank 2 running lean) is the cause so I looked under the truck to see if the front passenger sensor was good, and I seen a tube hanging no idea what it is for or where it goes. Any help is appreciated, thanks
Attached Thumbnails new problem ?-20150519_174429.jpg   new problem ?-20150519_174522.jpg
Old May 19, 2015 | 07:35 PM
dusty1's Avatar
Tube looks like a vent... Just came in clipped
I'd Check for vac leaks
Old May 20, 2015 | 05:54 AM
martin12's Avatar
Ok It looks like it comes from the motor or front end. I seen a hole like a bigger tube in the body going up I just stuck it in there for now. Didn't want the tube dangling on the driveshaft. Will look again after work and see if I can find where it came unplug from. Thanks
Old May 20, 2015 | 02:57 PM
Alphamale's Avatar
If the car was running well before you fitted the new Y pipe I'd be checking the joints with the manifolds. An air leak there could introduce unmetered air to the system that the O2 sensor signals as a lean mixture in the relevant bank.
With this signal from the O2 sensor the ECU tries to adjust the mix, but it's already ok and by altering it, a problem that didn't exist is created and the engine falters. It's also worth checking back through the air intake side of the engine for any other unmetered air leaks which will be detected by the O2 sensors.
The tube hanging down is one of the breathers from; front diff or gearbox or X-box all of which should pass into the engine bay and be strapped to the bulkhead safely away from the exhaust on the passenger side.
Old May 20, 2015 | 06:20 PM
martin12's Avatar
Well the truck ran good no problems, every now and then code po440 popped up but usually it was the result the gas cap wasn't tight enough. I decided to more or less race a cop car and that's when I first noticed the start of the sluggish-ness. Also changed the oil but I figure that is unrelated since I didn't mess with anything other that the oil pan and filter. I'm not showing any missing but could that cause a o2 sensor to get a little crazy? Or do I need to switch the sensor and see if the problem follows?
Old May 20, 2015 | 09:58 PM
disc oh no's Avatar
All 4 o2 sensors??? JAHEEEEZ!!! What was wrong with them? I replaced one on my Rover once a couple of years ago, but I've never heard of any vehicle needing all of them. Especially all at once!
Old May 20, 2015 | 11:43 PM
ls1morethanyou's Avatar
Trans vent, dont pull it! i did that on accident.... now i know i have a hole i need to plug up
Old May 21, 2015 | 09:13 AM
martin12's Avatar
Ok so leave the vent tube alone, can do will clip it up out of the way. Any ideas on the p1174 code?
Old May 21, 2015 | 12:08 PM
Alphamale's Avatar
The following is an extract from a table in RAVE. But while there is a recorded P0150 fault from the front O2 sensor in bank 2 i.e. right hand bank of engine, this could be a spurious code caused by an air leak anywhere from the MAF through to the upstream side of the sensor. Having said that do never-the-less make sure the connection and circuit of the sensor is sound. Get yourself a copy of RAVE here http://www.landroverresource.com/doc...hop_Manual.pdf and look up page 18-2-28
P0150 - O2 sensor circuit malfunction (bank 2, sensor 1) - Front sensor RH bank stoichiometric ratio outside operating band
P0308 - Cylinder 8 misfire detected - Injector 8 excess emissions/catalyst damaging level of misfire.
P0171 - System too lean (bank 1) - Multiplication injector adaptive fuelling - lean limit exceeded LH bank
P0172 - System too rich (bank 1) - Multiplication injector adaptive fuelling - rich limit exceeded LH bank
P0174 - System too lean (bank 2) - Multiplication injector adaptive fuelling - lean limit exceeded RH bank
P0175 - System too rich (bank 2) - Multiplication injector adaptive fuelling - rich limit exceeded RH bank
P1171 - System too lean (bank 1) - Additive injector adaptive fuelling - lean limit exceeded LH bank
P1172 - System too rich (bank1) - Additive injector adaptive fuelling - rich limit exceeded LH bank
P1174 - System too lean (bank 2) - Additive injector adaptive fuelling - lean limit exceeded RH bank
P1175 - System too rich (bank 2) - Additive injector adaptive fuelling - rich limit exceeded RH bank
P0300 - Random/multiple cylinder excess emissions detected - Excess emissions detected on more than one cylinder
P1300 - Random/multiple cylinder misfire detected - Catalyst damaging level of misfire on more than one cylinder
P1319 Misfire detected with low fuel level
Old May 21, 2015 | 06:51 PM
disc oh no's Avatar
Yep! That's a copied and pasted list of DTC's... That I now recopied and re-pasted.
I think he's looking more for the cause than the effect.... Is my guess.
