New problem with pulley
Old Jan 7, 2013 | 10:31 PM
AdrenalinPlease's Avatar
Default New problem with pulley
Probably due to coolant being all over the place, sounds like the idler pulley below the ac compressor has given up. What's involved?
Old Jan 7, 2013 | 10:37 PM
Fivespddisco's Avatar
This is a common failure part. Just replace it
Old Jan 7, 2013 | 10:42 PM
Ah, figures lol
My lift and tires are taking longer than I expected due to something constantly popping up
Old Jan 7, 2013 | 10:46 PM
5bravobravo's Avatar
Pretty straight forward, pull the top of the shroud for access (leave the hose), use a wrench on the nut for that same pulley to slack the belt enough to slide it off and out of the way, undo the bolt and pop off the pulley with the bearing. Mine just started squealing a few weeks ago so I swapped it with the one from my parts donor vehicle. What I'm not certain of is if you can get just the pulley with bearing, or just the bearing even, or if you have to get the entire assembly. when I get a little extra time I'm going to turn one up from aluminum on my lathe, the factory plastic ones are pathetic..
I'm sure that if you can get the bearing out, you can source a good quality bearing from mcmaster Carr or king bearing (applied.com) or whatever industrial supply you like to use for bearings.
Good time for a new belt if yours is anywhere near due..
Old Jan 7, 2013 | 10:48 PM
My belt is nice so I'm not planning on replacing it yet. Thanks!
Old Jan 8, 2013 | 11:21 AM
Will this pulley work for the one I need under the A/C compressor?
AMO Accessory Belt Idler Pulley : Amazon.com : Automotive AMO Accessory Belt Idler Pulley : Amazon.com : Automotive
Old Jan 8, 2013 | 02:10 PM
^^^anyone???^^^
Old Jan 8, 2013 | 02:46 PM
time sensitive help needed please...please...please...
Old Jan 8, 2013 | 02:59 PM
ZGPhoto's Avatar
It's extremely possible that it'll work. It is the correct size, the part number you need to replace is PQR500060.
Old Jan 8, 2013 | 03:23 PM
lr2001silver's Avatar
Banned
Your local auto parts store will have a pulley for this but if you want you could call Rovers North they will also carry what you need!
Pulley Idler 70MM Polyvee (Part # PQR500060) - Land Rover ancillary components from Atlantic British
