new push rods when doing head gasket?
Old 06-04-2018, 05:38 PM
09dewaed's Avatar
I measured the length of the rods and they are all within .5mm of each other. Although that difference is small, its enough for a gap.
Old 06-04-2018, 05:43 PM
Jeff Blake's Avatar
As long as the rods are in good condition AND you set the lifter pre-load correctly, then you are good to go
RPi Engineering - Specialized Rover Engines - faqs
Turner engineering sells a shim kit. I had to shim one of the rocker shafts, but not the other
Old 06-04-2018, 06:23 PM
09dewaed's Avatar
I’m hoping I won’t have to change or set any preload as I didn’t disassemble the rocker shaft..?
Old 06-04-2018, 06:25 PM
Jeff Blake's Avatar
Well since you mixed up the order of the push rods, you do
Old 06-14-2018, 06:02 AM
09dewaed's Avatar
I finished the Head Gasket job after putting the push rods back in using random order. The valve train is silent.
Old 06-18-2018, 08:20 AM
Roby466's Avatar
I just did that job and when the machine shop had the heads in they checked the valves. Disco has 126k miles and they said the valves were pretty much perfect. They checked them and there was no reason to lap them.
I ended up replacing my push rods because the lifters were damaged so I did cam bearings, camshaft, lifters and push rods. Two of the push rods had wear on the top but they were so cheap I got 16 new ones.
NoBama316
04-18-2014 08:46 AM
ejag42@mac.com
04-09-2014 09:20 PM
Eak69
05-02-2010 03:03 PM
cobbcj7
11-13-2009 07:41 PM
XCELLER8
09-19-2009 03:27 PM
Quick Reply: new push rods when doing head gasket?
