new roof rack
i suppose one could fit a higher spacer in the footing to give the extra clearance needed to clear the roof, and somehow space the footing so it does not rub on the roof,
but like i said when i have more cash i will get a sd rack. but not before i get a extra set of wheels and tires
Let me clarify, the towers hit the side of the roof above the gutters, and as you tighten the screws, they press against the body more. The Thules have a more vertical tower and will not do that. I think my solution is to buy eight Thule towers and four crossbars, which may seem like overkill, but overengineered is better than not enough. My reasoning is that in case I do need to remove the rack for whatever reason, it will be much more compact to store.
