New Rover V8 Engine Links
Since a lot of people come on the site for general info I thought I would put these links here, and show the options for new Rover Engines. FYI there is an LS Swap under development. I saw V8 Developments in a facebook group, and thought why not start a thread, maybe make it a sticky, where people whose blocks go can research. Of course, add any I miss.
https://www.turnerengineering.co.uk/
"RPi Engineering - Specialised Rover Engines"
Land Rover Engines
https://www.roverparts.com/Promotional/engine/
V8 Developments - Engines
Land Rover Engines
Discorama (02-10-2020)
Affordable Aluminum Buick / Rover Stroker Motor, by Kurt Schley
I thought this was cool if anyone is rebuilding from scratch. I would think a 4.0 block would be perfect for this setup.
You have to add Eric Brown's company https://www.trailhead4x4.com/
I have seen two of the conversions now and they are awesome
He is in Cleveland Ohio
CollieRover (08-16-2019)
The Kent Sports Torque H180 Cam really likes the porting and polishing I did, as amateur as it is, there is a noticeable difference especially passing. If I could do it all over again I would buy a Turner Long Block with the Cam and the gas flowed cylinder heads, and port match the exhaust manifolds. Sometimes it idles so smooth I can hardly believe it. That or go really nuts and get the Toddco 5.0l. As much as it is improved there is always room for more power.
https://www.automotivecomp.com/servi...mance-engines/
Found another builder of Rover V8’s. The LS Swap May make them obsolete over here, but having already purchased a Turner Sleeved Block I feel like I will stick with it.
Would eventually love to get a cylinder head with oversized valves and get the ECU flashed.
Yeah, not a big deal, but with ACE’s awesome LS thread that has all the info anyone could need to do the LS swap, it may be a bit redundant.
trailheads swap does maintain the Rover ECU which is cool, but I wonder if your better off with a GM ECU to tune yourself. Not many can tune the Bosch ECU.
