New Scanner under $200 reads OBD2 and ABS
Old Oct 9, 2013 | 09:50 PM
Racer X's Avatar
Welp, there goes the resale on my ABS Amigo.
Old Oct 10, 2013 | 07:27 AM
turbodave's Avatar
Sounds like RSW finally need to make the all-coms compatible with the D2 to remain competitive. They have been promising D2 All-coms for a long time now, and is why I've (personally) held off buying the Amigo.
Sounds like I'll be purchasing something else instead now.
Old Oct 10, 2013 | 12:45 PM
acg's Avatar
acg
Thanks for the info. Just ordered on myself!
Old Oct 10, 2013 | 01:30 PM
CaptainCulp's Avatar
Anybody interested in going halvsies on this? Or like, first person buys it, uses it for a few weeks, 2nd person buys it for 75% of original cost, but then has the option to keep it forever/resell?
Old Oct 10, 2013 | 05:19 PM
ralphobell's Avatar
I think the Amigo still has its place. It will give you the actual code #, the Autel does not show the code number but tells you what is the issue. The Amigo is faster for clearing the codes if needed. I have both and will continue to make use of both.
Old Oct 14, 2013 | 05:55 PM
acg's Avatar
acg
Thanks for the links and the instructions. My unit arrived today from Amazon. The update process went without a hitch.
Originally Posted by jthomas
Agreed. Here are some directions I wrote on how to update it:
First you have to update the scanner. You will need a MicroSD card reader.
1. Hook up scanner to any car - turn ignition on.
2. Go to 'Setup' button on scanner.
3. Go to 'About' button on scanner.
4. Write down your Serial Number & Password.
5. Register your product HERE and download the scanner update program HERE. You will need to choose 'MaxiCheck Airbag/ABS' option when registering, then enter your serial number and password you found on the scanner.
6. Install scanner update program. Enter your Autel.us username and password you created when registering the product (not the same as the serial number and scanner password)
7. Remove the black MicroSD card from the right hand of the scanner and plug into your computer via a MicroSD card reader. Most phones use a MicroSD card and they will usually come with a MicroSD adapter that goes into your card reader on your computer.
8. Update your scanner. I choose to update all the different manufacturers - 36 updates in all. You WILL need to stay connected to the internet for this.
9. When finished, it will tell you that all selected manufacturers have been installed. Remove MicroSD card from computer and adapter and reinstall in scanner.
10. Plug back into your OBDII port on your Discovery and it will turn on. Go to ABS/SRS --> European --> Land Rover --> Discovery --> 1998-2004 --> ABS --> Read Codes. Then it will show you your codes and you can also choose to clear them too.
And some pictures:
Old Oct 15, 2013 | 12:51 PM
acg's Avatar
acg
I have a SRS light (airbag/seat restraint system) on. I used this unit to diagnose the issue. The unit will not read the SRS system. There is an error message saying there is a "connection error". I can confirm there is no connection error as it is able to connect and diagnose the ABS system.
Can someone confirm if your SRS diagnosis feature is working please?
Thanks!
Old Oct 21, 2013 | 11:14 PM
acg's Avatar
acg
Thanks!
Can someone who has this unit confirm if it will read airbag SRS codes please?
Thanks!
Old Oct 26, 2013 | 07:51 PM
acg's Avatar
acg
I believe the unit does not read SRS codes. I tried it a number of times and I get a "cannot find connection" error message. I am returning the unit to Amazon and getting myself a Nanocom.
Old Oct 26, 2013 | 08:04 PM
The airbag function worked on my Dad's Sable and Windstar.
The abs works on Ford and Saab.
Pulls codes on Mercedes and all the above.
Don't have any Rovers this high tech lol
