New thermostat anyone have a good install guide?
Old Oct 17, 2019 | 11:32 PM
Carlos Man's Avatar
Default New thermostat anyone have a good install guide?
Hey guys just ordered this part, Is this the recommended one? Also if anyone has a legit guide for the instal I would greatly appreciate it!
engine is running around 210-215
Old Oct 18, 2019 | 12:07 AM
Discorama's Avatar
I made these helper clamps from hardwood and 1/4"x 2" carriage bolts + washers, wing nuts, clamped the coolant lines, opened the hose clamps, replaced the thermostat, installed and tightened new worm clamps, removed helper clamps. There is a small coolant loss, but no mess. Top up coolant and bleed. That's it.
Clamps
Clamps in action
Old Oct 18, 2019 | 02:14 AM
JUKE179r's Avatar
That is smart @Discorama !
Usually the thermostats are stamped with opening temperature labeled in Celsius. Here is the V8 thermostat breakdown:
- Cream is 190F/88C° with Hard Spring (Designed for TD5 and V8 applications) PEM100990B / PEM101020
- Black or Cream is 180F/82C° with Hard Spring (Designed for a V8 and used as a stopgap with Freelander K4 engines) PEL500110
- Grey is 180F/82C° with Light/Soft Spring (Freelander K4 engines)
Also there is a metal thermostat housing #AJ813558 for a Jaguar 3.0L V6 that you can add your own thermostat.
Old Oct 18, 2019 | 04:44 AM
SundayFunday's Avatar
You could read yourself about the inline thermostat mod, nows your opportunity..
Old Oct 18, 2019 | 06:14 AM
Carlos Man's Avatar
Originally Posted by realroverguy28
and you just wasted your money ... temps will go down maybe 10 degrees if that . its false advertising ,, this item is junk
okay so which is the correct part ... I can always return if and get the correct one.
Old Oct 18, 2019 | 06:18 AM
Carlos Man's Avatar
I did see something about that... what is the benefit of this mod? Considering it utilizes the game thermostat. Is it just less travel for the coolant?
could you help me out and direct me to a good build thread I’d like to knock it out this weekend.
Old Oct 18, 2019 | 07:15 AM
Best4x4's Avatar
Britpart 180F = stamped 78C inside & it’s an excellent thermostat.
Old Oct 18, 2019 | 07:23 AM
Carlos Man's Avatar
I’m assuming that’s the one I bought.
thanks, someone left a comment saying it was garbage then deleted it.
Old Oct 18, 2019 | 02:25 PM
cvhyatt's Avatar
Don't get this! I ordered it and was plagued by problems. Spend the extra $$$ and get the low temp genuine stat from lucky8.
Old Oct 18, 2019 | 03:43 PM
Best4x4's Avatar
I am honestly getting tired of the false so called britpart thermostats sold by a certain LR vendor. Plain & simple if it’s stamped 78C that thermostat is AWESOME and Britpart sells it. However plenty of fake 180F’s are out there.
I do not spread fake data or info, the true britpart 180F’s stamped as 78C are just as good as the grey LR OEM 180F unit at half the price.
