New twin pocket clear headlamp arrangement
Old Oct 2, 2004 | 10:14 PM
Darksidetone's Avatar
Default New twin pocket clear headlamp arrangement
Does anybody know if you can take the new twin pocket clear headlamp arrangement for 03 and higher Disco II's and put them in an older model? Any advice or knowledge would be greatly appreciated. Thanks
Old Oct 5, 2004 | 03:59 PM
Lighting90's Avatar
Default RE: New twin pocket clear headlamp arrangement
The answer is no, with regard to buying them from a Dealer, as they require a different bumper and the wings cutting.
Old Feb 9, 2007 | 08:17 PM
gnomeboythree's Avatar
7th Gear
Uh, the answer is actually "yes". It takes some doing, but it can be done. I am currently in the process of changing out the headlights and tail lights on my '00. You must unweld the front head light box, then modify it to fit the new bi-pod headlights. They will also need rewiring and some bracket fabrication. If you can get a used wiring harness off an '03 or '04 you'll save yourself a headache. Hope that helps.
Old Feb 9, 2007 | 09:15 PM
Yes, you can, as already mentioned it takes some effort but looks good when done.
Mike
abran
Apr 18, 2014 10:07 PM
houstonrover09
Oct 2, 2013 07:18 PM
Externet
Jul 27, 2013 02:07 AM
alanroberts50
Nov 24, 2009 09:16 AM
98roverguy
Sep 19, 2006 11:32 AM
