new u joints
Old Feb 4, 2015 | 08:31 PM
martin12's Avatar
Default new u joints
I seen some u joints on rockauto for 16 bucks a piece made by MOOG, are they any good or you get what you pay for with 16 bucks?
Old Feb 4, 2015 | 08:42 PM
joshjellel's Avatar
Mine were USA made (4 months ago) but the same store also had the same part made in Mexico, and I had to purposefully ask. If that kind of thing matters to you, just be sure to read the box or ask.
Old Feb 4, 2015 | 08:44 PM
joshjellel's Avatar
I also paid more than that. I know when I was looking, without fail, if it was less than $20 it was imported from a country you probably wouldn't want to get car parts from.
Old Feb 4, 2015 | 10:11 PM
OverRover's Avatar
The Moog 344 is not the worst joint in the world. I have seen them fail and that's why I will not run them. SO spend the extra money and get a far better part with a GKN TVC100010G (HD) or GKN TVC100010D (MD).
Compare the moog and the GKN side by side. The bearing in the MOOG are tiny. For years I've always had good results with GKN joints.
I know RovahFarm > RovahFarm for all your new Land Rover Parts and Accessories and Lucky8 both have very good prices on GKN. Call them, it's worth the money.
Whatever you do NEVER buy or even except as a gift GMB!!! Water pumps, U- joints, anything! Total scrap.
Old Feb 5, 2015 | 04:57 AM
martin12's Avatar
Ok sounds good I'll check with lucky8 and see figured I'd ask. Thanks
Old Feb 5, 2015 | 08:10 AM
OverRover's Avatar
Always smart to do your homework. I'm confident that Justin/Erik @ L8 will have a similar opinion re: GKN joints. And maybe the best part of that is it won't be a shop trying to give you a B$ up-sell.
Old Feb 5, 2015 | 02:58 PM
OffroadFrance's Avatar
IMO and experience GKN HD and Hardy Spicer HD are the best and last the distance. You get what you pay for in UJ's. It's not worth skimping on the time and effort on a rebuild, particularly the Cardan joint, just to have it fail again in a few thousand miles. GKN are the usual OEM and usually last 100K miles first time around so no better recommendation.
Old Feb 6, 2015 | 08:39 AM
drowssap's Avatar
I would have to agree with the moog ujoints. Mine stb quite quickly, good frontend parts not no ujoints
Old Mar 12, 2015 | 06:06 AM
martin12's Avatar
Finally got my new u joints, took a little while due to the bad weather. I got the HD kind from lucky8. My question is, is there a certain way they go in or just remove the drive shaft, remove the old joints and then install the new ones. Also do I need to replace the ball bearing in the cardon joint or will I be ok.
Old Mar 12, 2015 | 06:28 AM
drowssap's Avatar
