New Y-pipe Suggestions??
Old Jul 7, 2015 | 09:37 PM
Madlands's Avatar
Default New Y-pipe Suggestions??
The high flow magnaflow universal cats my independent LR guy put in a couple years ago are done in. The rattling has become unbearable so I'd like to replace with a new y-pipe. I would consider new universal ones, but the welds are so bad (1 02sensor is welded to the pipe) I just don't see it being worth the trouble.
I'd like something in the $400 range if that's possible. Davico prices and reviews are very mixed so they have me a little nervous. There's also an AB catalytic ypipe on Amazon for around $440, but with no reviews. Anyone have experience with either or others in that price range?
Old Jul 7, 2015 | 10:39 PM
Charlie_V's Avatar
I have the davico pipes and they work but are not well formed. I had to bend the brand new pipes to get off my front driveshaft and to mate with the flange in front. They do work with modifications though. Had mine for a couple of years.
Old Jul 8, 2015 | 08:29 AM
Madlands's Avatar
That's what worries me about the davico. If I buy something new I would like for it to fit without having to do any modifications to it. Thanks for the input. Anyone else?
Old Jul 8, 2015 | 08:08 PM
coors's Avatar
Fitment for me was smooth but...
Since day one my B1S2 O2 has always read funky - readings were all over the map.
A few months back the Drivers' side catalyst (B1) dislodged from the internal housing and began to rattle, obnoxiously . Davico markets a lifetime warranty, but I did't get a chance to register for an RMA (if you follow my threads you know why)
Old Jul 9, 2015 | 06:50 AM
Your bigger concern is not the "Y" pipe but what killed both of those Magnaflow cats. Do you have any fault codes, is the engine running poorly, have you blown a head gasket and what octane gas are you using?
Old Jul 9, 2015 | 07:55 AM
Madlands's Avatar
The rattle is what concerns me at the moment because it's so awful. I had a vacuum leak I never quite got under control but I've noticed a broken stud from the manifold to y pipe so I'm hoping that's the problem. Engine runs just fine, head gaskets fine, gas is premium. I just don't want to pay $600 for a y pipe.
Thanks coors. I'm starting to stray from the davico idea. Warranty is great and all, but I've never had a smooth warranty claim go through.
Old Jul 9, 2015 | 09:05 AM
Madlands's Avatar
Anyone had any luck with the magnaflow y pipe? I just ordered the magnaflow 93689 y pipe for $445 with free shipping off eBay.
Now to find the most affordable Bosch front O2's.
Old Jul 9, 2015 | 12:03 PM
Your pipe selection is important but what caused your other cats to fail is the issue you need to address otherwise any new cats/y-pipe will also fail.
Old Jul 9, 2015 | 12:19 PM
Madlands's Avatar
I can't find the cause until I get them replaced. The only codes I ever get are for dead cats and then sometimes a slow O2 reading on bank 1.
Old Jul 9, 2015 | 05:11 PM
Maybe this will help you, when was it last tuned along with new 8 mm plug wires, do you get smoke be it blue or white from your exhaust, been having to add coolant and or burning oil?
