No Cats On Disco 1
Old Sep 2, 2008 | 12:25 PM
sailorcolin's Avatar
Default No Cats On Disco 1
I have a 1996 Disco 1 and keep getting the trouble code P0420. I have linked it to bad Catalytic converters. I was wondering if i remove them temporally if my disco will run ok with out them.
Old Sep 2, 2008 | 12:38 PM
Landzu's Avatar
Default RE: No Cats On Disco 1
On a 95 you could but on a 96 you have O2 sensors after the cats .
You would end up with more codes.
Old Sep 2, 2008 | 12:42 PM
besides codes will anything else be affected?
Old Sep 2, 2008 | 12:51 PM
Landzu's Avatar
It will run lean ,, could burn a valve.
Old Sep 2, 2008 | 12:52 PM
thanks
Old Sep 2, 2008 | 01:02 PM
Landzu's Avatar
You can get cats put in a lot cheaper than buying a Y-PIPE.
I picked up a preformance Y-pipe with cat's and can not tell that
it added anything other than it got louder.
Old Sep 2, 2008 | 03:13 PM
Sailor,
Have a concern, you have posted at least 6 different issues today, all the while mentioning you don't/can't spend much money on it and now you want to run without cats till you can afford to replace them. This is a long step from one of your posts regarding wanting to to a 4.6 conversion.
Don't take this wrong, or not, but you sound very young and even more uncertain about what you want to do with your truck.
You might want to take a couple deep breaths and put a list together, by importance as to what needs to be done to get your truck running properly and if you survive that financially then what change/upgrades you want to make cause you are all over the map at this point.
DuplinDisco
Aug 14, 2019 06:50 AM
gmscando
Mar 28, 2011 11:51 PM
RoverTCV8
Headers, Intake, & Exhaust
Feb 18, 2009 01:15 PM
sailorcolin
Dec 4, 2008 01:25 PM
riebs
Oct 24, 2006 07:00 PM
