NO HEAT AT FEET
Old Feb 12, 2007 | 06:30 PM
84 GRANDSPORT's Avatar
4wd High
Default NO HEAT AT FEET
I have heat however when I switch it to feet it does not switch it to my feet...What is the possible problem? I am a DIYer so I want to fix it myself but beforeI start removing under dash stuff...Anyone have this issue? What parts will be needed?How much is the part/parts?Thanks in advance!
Old Feb 12, 2007 | 06:39 PM
4wd High
Default RE: NO HEAT AT FEET
I want to add its a 97 disco with 127k...sorry for not writing that in first post.
Old Feb 12, 2007 | 07:39 PM
It could be the heater control unit failing or a air gate not opening to the floor area, either way, I wouldn't suggest you tear into the dash, it is a bear.
Mike
Old Feb 12, 2007 | 07:57 PM
4wd High
ORIGINAL: Disco Mike
Mike
Mike I have done heater cores on 5 series Bimmers (nightmare!) soI am not afraid to do a job like this. I was more looking for some insight on what is involved in the job & possible parts involved....I was thinking maybe this was a common thing & someone would know a fix.IfI fix itI will post it.
Old Feb 13, 2007 | 06:35 PM
geoman's Avatar
It's probably the Control unit (part number AWR 7154) which is a one piece unit with the mechanical gears, cables, and servo's. They fail with some regularity. I have the part for $175.00. It beats the hell out of changinging out a heater core, which is a real Bear on both the Discovery and Range Rover.
regards,
Geoman
www.eurotekapg.com
Old Feb 15, 2007 | 11:24 AM
4wd High
ORIGINAL: geoman
regards,
Geoman
www.eurotekapg.com
Thanks for the input I was looking for...I actually got lucky...I started moving the switch back & forth several times & now have heat at the feet! I also found the wire for the aftermarket CD changer stuffed in the fee vent (someone has no brains) which I am sure was also restricting any air that wastrying to comefrom down there...Anyways thanks for trying to help...If for some reason it stops working again & I will be in touch with you about purchasing that part.
honda50r
Mar 8, 2012 06:38 AM
honda50r
Nov 5, 2011 01:13 PM
Rover Chris
Oct 2, 2010 09:39 AM
pvenuti
Apr 17, 2010 05:20 PM
swellseeker
Feb 15, 2007 02:15 PM
