No heat while idling?
Old Mar 4, 2009 | 06:02 PM
IDAHODISCO's Avatar
Default No heat while idling?
When I am idling and I have my heater set on high heat it blows a slightly worm air out, but as I started to drive down the road it started to blow worm er air the faster I went the worm er it got? What you should now is this is a new disco to me with 120,000 miles the air does blow hard just not worm I looked at some fuses and could find any thing I looked to see if the heater core was disconnected and the two port that go through the heat shield are hooked up!
What should I do next?
Old Mar 4, 2009 | 06:06 PM
AK Rover's Avatar
Did you do a search for this problem? This is very common and covered like a million times now. Check your coolant level first then let us know if that isn't the problem.
Old Mar 4, 2009 | 06:21 PM
okdiscoguy's Avatar
bleed the coolant system. Check your engine temp. If no air in coolant, replace thermostat.
Old Mar 4, 2009 | 06:34 PM
IDAHODISCO's Avatar
O well I will take a look at the coolant level then! I never had to fix anything on my 03 I guess im going to learn a lot now YAA!
Old Mar 4, 2009 | 06:39 PM
AK Rover's Avatar
At some point your 03 will more than likely experience everything your 00 does, for the most part. Take notes of the symptoms and the fix so you know what to do when the problems start to pop up on the 03. You've got an excellent opportunity to learn from the 00.
Old Mar 4, 2009 | 09:54 PM
IDAHODISCO's Avatar
I just replaced the three top hoses they looked a little ballooned I will get the others later but their was very little coolant in the hoses when I removed them! I was able to get a full coolant bottle in it so far and still no heat while idling!!
So I will let her cool down and I will just keep topping her off!
FYI It has never ran hot in fact it runs cooler than the 03!
Old Mar 5, 2009 | 05:57 AM
You need to bleed the air out of the cooling system and replace your thermostat.
It runs cooler because your t-stat is bad which means bad for the engine.
Old Mar 5, 2009 | 10:54 AM
okdiscoguy's Avatar
not even sure why I post sometimes..........
Old Mar 5, 2009 | 12:00 PM
IDAHODISCO's Avatar
Me either because you said "Check your engine temp. If no air in coolant, replace thermostat." well sweetie I had AIR!!
No I get it spike I am from AZ if you have a bad thermostat you over heat I never thought of running cooler I guess the reason is it never fully closes! OK well I will move that back to the top of my list ARRRRR.
Thanks
Old Mar 5, 2009 | 12:21 PM
Bottom line, if you haven't bled the system and or don't know how, send me your tele number and I'll walk you thru this.
