No Running lights...keep popping fuses on '96 disco
Old Sep 20, 2009 | 10:04 PM
Whitepine's Avatar
4wd High
Default No Running lights...keep popping fuses on '96 disco
I have checked the bulbs, fuses in truck and in the engine compartment on my 1996 disco. The bulbs are new. I first had issues with the driver side rear running lights and now both are out. And I keep popping fuses. What else should I check?
Old Sep 21, 2009 | 07:24 AM
kenk's Avatar
Is it wired for towing/trailer? If so, go over that wiring. I've seen some crappy DIY wiring jobs. Check all the running lights sockets. I hade to replace a few of mine they were corroded so bad
Old Sep 21, 2009 | 02:01 PM
Do your dash lights work?
Old Sep 23, 2009 | 06:40 PM
Whitepine's Avatar
4wd High
Dash lights work. It has a "uhaul" trailer harness.... I was thinking that might be the root of the problem.... hopefully not tip of the Iceburg.
I will check all the wiring sockets.
Old Sep 23, 2009 | 08:51 PM
Whitepine's Avatar
4wd High
found a socket that was grounding out on driver side....new fuses and now they work!
thanks for all help.
Old Sep 23, 2009 | 08:56 PM
Eurotrash's Avatar
This could be and issue with the trailer Harness. Does it blow the fuse only when pulling the trailer?
When I pull my race trailer with my Chevy,I have to remove the trailer harness ground or it will blow the fuse for my reverse lights. The chevy grounds the trailer through the hitch. But when I pull the same trailer with my Daugthers Ford Excurstion the trailer ground in the harness must be connected. The Ford grounds through the harness.
Old Sep 23, 2009 | 10:05 PM
IDAHODISCO's Avatar
Then I would say your trailer is fine but you truck has a direct short to ground find the hot that controls the reverse lights and do a continuity check to ground if you have tone then find your short! I would think that could rule it out but I am just a electrician not a mech electrician!
Roverluver
Aug 17, 2013 03:06 PM
B.Young
Mar 30, 2011 11:11 AM
dgee03
Nov 20, 2008 05:59 PM
Disco2Guy
Feb 22, 2008 02:39 PM
